I've done a LOT of reading about what box oil to use in my 33. Castrol VMX80, Syntran and Redline Lightweight Shockproof were the 3 tops selections (Royal Purple was also mentioned a few times).
Well today I bit the bullet as I wanted to change the oil to ensure it was new and in doing so hopefully smooth out or eliminate a clunky feel from 1st-2nd and an occasional grind from 3rd-4th when changing at high revs. I opted for the Redline option as 99% of people who use it SWEAR buy it, and that's in light of the rather high price.
The 2nd problem I had was how much oil would I need. I made many calls and received a WIDE range of responses. The actual truth of the matter is very simple. In my Series II R33 5 speed manual transmission, I did NOT use all of the US Gallon (3.785L's). There's still 3-400ml in the bottle indicating a capacity of ~3.3-3.5L's and this was when the oil started coming back out of the filler hole. We also filled the car on even jack stands front and back to be sure it was filling evenly.
I also purchased a 1L suck and blow as I call it, shown in the pics, which made putting the oil in a total breeze. Some pics are attached and are captioned accordingly.
Now, the important stuff. After going for a drive, there is a noticeable improvement in smoothness through gear changes under normal driving conditions. Under hard driving conditions the improvement is even more noticeable, the box made the dreaded grind noise only once from 3rd to 4th and I'm told that with a few hundred K's the improvements should be greater still, this could also easily be due to a worn clutch. Bottom line, the oil DID make an improvement. It is up to you if you feel that the improvement is worth the $130 or so (if you can get it cheaper awesome but I'm in a regional area and this was available on the shelf today when I needed it).
I'm of the frame of mind that given how long this oil can stay in the box, you might as well spend extra $50-$70 and do it right with a proven oil rather than trying to save that money and not getting as much an improvement from another brand. Having said that, I have not used any other brand and can only give you my impression of this oil.
So the important stuff...
The oil DID make an improvement.
The gearbox takes around 3.3-3.5L.
One US Gallon, WILL be enough to fill the box with some left over.
I now have 3-400ml left over that if someone needs to top up there box, they can contact me and we can work something out.
Now for some pics!(There's a tutorial on these forums about how to change the oil, it's very simple and quite accurate, read that if you're unsure on how to do this).
You will need....
Now get under the car...
Drain all the oil out and be sure not to lose the plug into the oil as it has a magnetic seal which should pick up all the worn case hardening. Give it a clean, here's some before and after. I imagine this oil was the original stuff 0_0
Before
After cleaning
When you put the drain and filler plugs back in use some loctite, it's your friend and will ensure your precious fluid stays in.
We filled the 1L bottle a few times and pumped it back into the box.
Fill it til it starts to come back out the hole then put the filler plug back in and you're done. Now go for a drive and see what you think!
I hope this helps someone and saves them doing all the bs I did to find out what was what =)
Cheers
Edited by ActionDan
  • Replies 56
Ive done this oil change as well and my god it makes a difference I never thought possible with an oil change. A good upgrade for sure and the well worth the money spent.
hmm... my gearbox is 10 years old... seems to be in good condition.. doesnt seem to make any crunching or wierd noises....
what oil do you recommend i slap in it ?? I was all set to get the redline until i read the last few posts...
Every import mechanic I talk to swears by Redline Shockproof. Every specialised clutch/gearbox 'normal' mechanic I talk to wouldn't touch it with a 10ft pole.
Well it seems we have some divided opinion, which is great to see. My point here was to share 'my' experience with the product in the hopes of helping others make a more informed decision.
Others can feel free to note their own experiences with the redline products or indeed any other gearbox product as it can only server to give people more info to use in makig up their own minds.
Cheers
Cheers
So what exactly does Nissan spec for this transmission?
Gear lub viscosity?
GL-4 or GL-5?
LSD or non-LSD?
well from personal experience, i've had it in my series II r33 gts25t for about three years now. when i first bought the car it had some unknown oil in the gearbox and it had the famous 1st to 2nd crunch, especially when cold. ever since then i have run redline lightweight shockproof in the box and it has been smooth as. it actually took about a month for the crunch to completely disappear after putting redline in. i just drained it a few weeks ago and put some more fresh oil in. i'm a fan :D
  • 1 month later...
 Share
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
    • Yeh a meagre benefit, what strut tower brace are you using? Eventually all the suspension and tyres are done and you get to ... meagre benefits. Narrow end of the wedge, all that stuff.
    • Yeh not doing anything with spacers at all, ty for the info
