  • Replies 56
oil world sold me redline gearbox for $100, but that was almost a year ago.
It's funny, you put it in, and don't really notice much difference, it takes about a week to really start working, it must take a while to get into all the gears and what not. or maybe i'm just imagining it!
redline gearbox oil is pretty high on my list of "good mods"
I have had a leaking gearbox reverse switch (i think) for a while now, i really should fix that, it's like liquid gold! $5 a drop
I have used the "blue Smurf" in 2 RB20/30 gearboxes now, boht after developing synchro issues.
The first one spat the mail bearings after 15K Km of use with the red line stuff, but i blame that almost enitrley on a failed spiggot bush.
The second gearbox has only just had it put in, and had immediate improvement.
My 3rd gearbox, which is in another car has Castrol MTX gear oil in it. It is 1/4 of the price and has worked just as well as the blue smurf. It is listed as a motorbike oil, and is quite thin however i was told it was still suitable for this application. My only concern is that the bearings may not love it, but it hasnt been in there long enough to tell. Just another option if your looking for a quick cheap fix.
Brent.
  • 1 month later...
So is there any conclusive evidence against Redline oils on new gearboxs/syncros?
This topic really left me undecided because I'm putting in a new box but still with an unknown condition. :
you mean a second hand box, thats new to your car?
i'd say it'd be fine...unless its just been rebuilt....
The one or two reports that said DON'T USE IT WITH A MINT GEARBOX are enough to put me off. I'll use Motul Gear 300 in my gearbox and diff instead, I reckon. I'll start using Shockproof when my synchros wear out :(
i am currantly running superlight shockproof and find it quite good once its warmed up say a few minutes,very silky shifts,, so yeah i feelit is good:-)
You can actually rate Redline lightweight shockproof as 75w140 but it is build very differently. One of the must have if you are generating big power.
Clink link below for more technical details:
RL lightweight shockproof
Edited by Trex101
The one or two reports that said DON'T USE IT WITH A MINT GEARBOX are enough to put me off. I'll use Motul Gear 300 in my gearbox and diff instead, I reckon. I'll start using Shockproof when my synchros wear out :mad:
Don't use it with a mint gearbox??? Where did u get that from? So if your gear box is fine, you shouldn't use redline oil at all?
I was under the impression that the consensus seemed to be don't go Redline if your box is new/rebuilt but go for it if the Synchro's are a bit older or a little tired =) I'm still yet to have any problems with it and the box is still noticeably smoother than it was and also eliminated grabbing under WOT through 2nd -> 3rd and 3rd -> 4th. I still need a new clutch and I'm hoping that will be the end of any grabbing through changes all together (as it will still do it occassionally through 4th -> 5th at high RPM.
Cheers
Dont use the shockproof. Its got additives in it to make it a thinner more slipperly oil. Normal non shockproof oil should be ok. Id probably go the castrol or motul stuff tho if your gearbox is in good nick.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
