Probably the very first few had ABS still as an option, but i'd check to make sure its a genuine series 2 and not really a series 1 disguised with the different bonnet and frontbar.
But concerning ABS and whether its a needed feature, I wouldn't be too stressed personally, I don't have trouble stopping without it :D All ABS does is if you even out the braking a bit more so during an emergency or in the wet it prevents them from locking up so much. If you're getting to that stage, then well I wouldn't be relying on a computer to save me.
https://www.sau.com.au/forums/topic/11442-abs/#findComment-194621
Originally posted by ice180
ABS is still an option even on series 2 more had it than series one but not all. The one I have for sale has ABS
Richie is right. When I was looking for mine, 90% of the ones I looked at in Japan didn't have ABS. Seems people were too tight to pay extra for it.
https://www.sau.com.au/forums/topic/11442-abs/#findComment-205153
Yeah, ABS on *all* R33s is an option.
ABS was a primary concern for me, but the perfect car came up - but no ABS - never looked back. If you have the opportunity to get it, I would because it's safer, but don't hold out for it.
I reckon the first month is a bit of a milestone if you're not used to such a powerful car, so just be careful - ESPECIALLY IN THE WET.
You will hear everyone tell you that and you may not take heed, but it rained the first day I got mine and I lost the back bigtime. I was lucky no one was in the lanes to the left and right of me :P
https://www.sau.com.au/forums/topic/11442-abs/#findComment-205803
I think most of the automatic will come as ABS as they're more of luxury items. Mine came with one, but I've ditched my auto and chucked in a manual gearbox 2 months ago.
The only thing if your car don't have ABS and you have to make a hard braking in the wet, never kill your pedal by stomping on it as it will lock all your wheels and slide your car even further. As soon as you hear/feel your wheel locking lift up the pressure off your foot a tad so the brake pressure is in the treshhold before locking your wheels.
Needs practice, but when done properly, you can stop as quick as an ABS equipped car. Try finding an empty street on a rainy day and do that practice until you know what amount of foot pressure you need to stop without locking your wheels.
https://www.sau.com.au/forums/topic/11442-abs/#findComment-207493
This unbelievable. u peoples think u can stop a car as good or close enough to an abs equipe car? I've been to enough race day and drive day to know one thing, human response is not even close to abs . why do u think it was ban from f1 and the times goes up. unless u can pulses ur right foot on the floor at the rate of about 100 times a second. get a car with abs.
https://www.sau.com.au/forums/topic/11442-abs/#findComment-208803
I agree with Hippy. You hear alot about how a great driver can stop better without ABS. Well, most people are not great drivers, and even great drivers don't pay enough attention all the time.
I'd prefer to avoid the accident than have a seatbelt and airbag keep me safe when I have one.
https://www.sau.com.au/forums/topic/11442-abs/#findComment-208970
Oh, and I should add, even on the track I prefer ABS (although full on racing is a different matter).
While you don't have to use it (ie you can stop just as well as you would without ABS), you can also be 100% sure that you aren't going to flat spot some expensive track tyres with a lock up. I've killed more tyres with flatspots when racing than I ever have worn out almost!
https://www.sau.com.au/forums/topic/11442-abs/#findComment-208983
newayz, the seriesII should have an electronically controlled LSD as well as a different interior trim, which granted can be swapped over to fool you, but you also get the dual airbags and you should be able to check here goes.... something on the seatbelts guys, i am not sure if this is right, but yeah something there is stamped with a production date. i mean there is an excellent chance that it is a series II especially if the plate has 1996 on it. and yeah be wary of the ABS cos if you are going from a rice rocket FWD to this monsta you might want the ABS especially if you have a slightly larger right foot that you have trouble holding up. also the series II dash cover (read: the fascia thingy that surrounds the stereo and climate control) is a different grain and is also more 3d than the series 1 and there is no coin box/slot thingo in it.
okay thats it from me
https://www.sau.com.au/forums/topic/11442-abs/#findComment-210540
Originally posted by NO_RSPECT
newayz, the seriesII should have an electronically controlled LSD.
Nope, this is only the A-LSD versions. It is a whole different model, not just an option.
Problem is, that any complied car will have had its seatbelts changed so you can't really check this.
https://www.sau.com.au/forums/topic/11442-abs/#findComment-210600
Yepp - Phil is spot on there. Seat belts would've/should've been changed.
A quick way of checking the date of manufacture is to look at the date on the vacume hose going to the brake booster thingy on the left hand side of the engine bay (standing at the front of the car looking in).
But the only true way is to get the VIN number and check through Nissan some how.
J
https://www.sau.com.au/forums/topic/11442-abs/#findComment-210808
yeah, that is very possible to check - i copied down al the details from my original compliance plate - the jap 1 -and called up some nissan dealer - cant remember which one, and they give u build date, as well as color, trans etc. should be more than enough info for u.
and i think it would be a major pain in the ass to change front lights, bonnet, front bar, dash, steering wheel, trim, rear fill panel (between indicators) etc just to trick someone, IMHO....
https://www.sau.com.au/forums/topic/11442-abs/#findComment-210861
Not going to argue the value of a good ABS system, however some of the early systems were a bit scary - as in not very well calibrated (especially for OZ conditions). I know this first hand from some of the old company cars I used to beat about in during the early nineties (in the days of my youth...sigh). My speedskyzer does not have ABS, is the system three channel or four channel, who has it, and used it? How effective is it?
https://www.sau.com.au/forums/topic/11442-abs/#findComment-210875
Pretty sure it's 4 channel as it has speed sensors on all four wheels and heaps of seperate pipes coming from the cotrol doova in the engine bay.
I've only used mine twice - once was to brake hard and swerve to miss a car that pulled out (it worked a treat that time), and the other time was in the rain when I stompped on the brakes a bit hard.
I found it was fast to react and worked well, but then again, this is the first ABS'd car I've driven....
J
https://www.sau.com.au/forums/topic/11442-abs/#findComment-210896
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
