I just used the generic heavy duty limited slip stuff they sell at GP Auto. Cost about $20 for 1 litre. By generic I don't mean it was crap, I just can't remember the brand. $20/litre isn't cheap :)
thx guys,
just bought the redline products and thought they r a little expensive ($140 4 6lt's), but i would have to say that it is well worth the money as it is alot easier to change gears now and the diff is way quieter than b4, and the car actually feels smother as well, wicked product. i bought it from oil world in herald st cheltenham........
they where really helpfull, explained all the diff oils and how they work b4 he let me buy the redline stuff...........
Steve
Diffs
According to my owners manual (JPNZ) R33
Viscas Non LSD.......1.0L
Active LSD .......1.6L
4WD Front ........1.0L
Rear .........1.3L
All other types ..........1.3L
Gearbox
2WD RB20E ...........2.0L
RB25DE ...........2.5L
RB25DET ...........2.8L
4WD RB25DE ......... 4.1L
Active LSD uses Power Steering Fluid
Can anyone supply this info for the R32 ?
Steve
They got a phone number/web page???
I did the diff without a hoist.... Took about an hour by the time I fiddled round... just make sure you have a oil pump with a flexible hose to pump the oil back into the diff... And my 3inch exhaust was in the way really bad :D you gotta try and work around it
Cheers
Sumo
P.S. I could only buy that oil in a 4 litre container.... its bloody good shit
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
