Drivebai Posted April 21, 2006 Share Posted April 21, 2006 HI, When my car is idling, the engine fan seems to be really loud. Also when you rev the engine is the fan suppose to increase it's speed with the revs as well? (this occurs when the engine's cold and when it's warm i vaguely remember reading somwhere that this was a clutch bearing problem or something but i can't find that thread anywhere. Any help would be great. Thanks Link to comment https://www.sau.com.au/forums/topic/114452-loud-engine-fan-is-this-a-problem/ Share on other sites More sharing options...
MerlinTheHapyPig Posted April 22, 2006 Share Posted April 22, 2006 the engine driven fan uses a viscous clutch to prevent it from spinning too fast, with the car off you should be able to turn the fan freely, if it's stuck/siezed then that's probably the cause of your problem. Link to comment https://www.sau.com.au/forums/topic/114452-loud-engine-fan-is-this-a-problem/#findComment-2110131 Share on other sites More sharing options...
Kryostaisis Posted April 23, 2006 Share Posted April 23, 2006 with the car off, gently move it around if you can feel any sort of friction, even the slightest bit, it will cause your fan to vibrate and become noisy. it wont harm your engine extensively, but it will put more strain on it, also your belts will experience the same thing. i had a smililar problem at 5000rpm... i replaced the fan and hub with new ones.. but in the end opted to use a thermo-fan to suit my application. oh, and make sure you check your hub, there should be 4 nuts that hold it in place. make sure they are all tight, it could be just the hub becoming loose Link to comment https://www.sau.com.au/forums/topic/114452-loud-engine-fan-is-this-a-problem/#findComment-2111078 Share on other sites More sharing options...
Drivebai Posted April 26, 2006 Author Share Posted April 26, 2006 Cheers guys Will check this out. I can move it but it doesn'tspin too freely. IF i try to spin it it will move maybe a quarter of a rotation. Link to comment https://www.sau.com.au/forums/topic/114452-loud-engine-fan-is-this-a-problem/#findComment-2118397 Share on other sites More sharing options...
Busky2k Posted April 26, 2006 Share Posted April 26, 2006 Test it when the car is warm. Don't do it cold as there will be excessive friction because you need to spin it at idle speed for 10 or so seconds before it becomes freely spinning (due to the oil distribution in the viscous clutch). Link to comment https://www.sau.com.au/forums/topic/114452-loud-engine-fan-is-this-a-problem/#findComment-2118514 Share on other sites More sharing options...
