actually just use your mouth, yelled out the noise and you will be sweet!!
BOV and pods are the latest generation of wanky factors nowadays in this car scene, just remember BOVs dont do shit! i have a factory one on mine and it actually works better. so what u want the f**ken noise for?
oii oii, I'm getting trashing of my life, gone doing assignment..
Yes of course I meant Atmospheric Blow off Valve (BOV). The plumb back makes next to no noise at all and in this context, "sound" is the key.
Atmospheric BOV does increase fuel consumption just do a search within this forum itself. They also causes the car to stall if set incorrectly.
If GTT factory claimed flywheel hp is 206. Then my car must be smoking weed to be able to achieve 200hp at the wheels, stock. While at it, what is the factory rated power for GTR? 206 as well isn't it? This is because of a gentlemen’s agreement between Jap cars manufacturer (Wikipedia, 2006)
Also 206 figure at the flywheel is not in the unit of Hp...It is actually 206KW at the flywheel or 280hp.
“A (now-defunct) agreement between the major Japanese auto manufacturers to limit the maximum advertised engine power of their cars to 280 PS (206 kW or 276 hp).” Wikipedia,2006
Quoting myself “also apparently stock GTT suppose to have abt 206hp”
“Apparently” means it seems that or seemingly (Cambridge, 2006). I’ll explain further: “meaning I am not sure”
A comparison between my Dyno result and rumours that have been going around (206hp at the wheel, not flywheel!!) cannot be established as a definite implication
If everyone choses to be so specific a plumb back valve is not a blow off valve...it's termed a bypass valve (Hide, 2006)
“Blow-off valve (BOV) / Dump Valve / Vent valve
This valve type features an adjustable spring design (spring in compression) to keep the valve closed under idle, cruise and boost conditions (eg 0.5 bar). Only at sudden throttle lift-off (eg 0.8 bar) does the valve momentarily open to vent / dump the pressurised air directly to atmosphere through a specially designed orifice (and wooshtssh).
Compressor bypass valve (CBV)
In the CBV case, pressurised air is returned to the turbo compressor inlet for reuse, instead of being dumped to atmosphere. The bypass valve is open under normal low-load engine running conditions, and closes firmly when positive (boost) pressure is present in the inlet manifold (or plenum chamber). When on-boost and changing gear (throttle lift-off), a sudden lower pressure condition is created in the manifold and the valve is pulled open again, directing pressurised air back to the turbo inlet.” (Hide,2006)
Last note:
Do your own research before believing in whatever people type in forums.
Jesus…there I’ll go back to my assignment
Reference
Wikipedia the free encyclopedia: Nissan Skyline, 2006. Retrieved May 3rd, 2006, from, http://en.wikipedia.org/wiki/Nissan_skyline
Cambridge Dictionary Online: Apparently, 2006. Retrieved May 3rd,2006, from, http://dictionary.cambridge.org/define.asp...=3513&dict=CALD
Hide, A. Compressor bypass valve (CBV) / Turbo Blow off valve (BOV) / Dump valve / Vent valve, 2003. Retrieved May 3rd, 2006, from, http://wwwrsphysse.anu.edu.au/~amh110/Tech...w_off_valve.htm
Wikipedia the free encyclopedia: Gentleme’s agreement, 2006. Retrieved May 3rd, 2006, from, http://en.wikipedia.org/wiki/Gentlemen's_agreement
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
