Hi all,
Just wondering how your Stagea handles in the Snow (preferably manual).
Has anyone done much driving above the snowline in their Stagea?
How does it handle?
Did you need chains?
Any other problems?
Cheers.
https://www.sau.com.au/forums/topic/114465-stagea-in-the-snow/
Like a snow mobile. You wont need chains unless driving on ice skating rink type ice. which only happens once or twice a year any way. Just drive smoothly when braking and turning. If you are ever forced to fit chains put them on the rear wheels and don’t drive above 30 - 40kmh or so.
us Ausies are wooses when it comes to driving on snow. In Canada I saw Harlies being driven on frozen ice covered roads.
Haven't driven the wagon in snow yet. I once drove a Mk 5 Cortina I had about 50Km through snow, without chains. You just have to drive very smoothly.
The Stagea is good fun on loose gravel, I just put it in 50:50 and it holds drifts really easy. It must look funny a large wagon going along at about a 30-40 degree angle down the road!
Hi all,
How does it handle?
Any other problems?
Cheers.
is this wat you have in mind doing? :D
I've done plenty of driving in my A4 Quattro in the snow - the grip in that was pretty amazing, but the Stagea is much heavier and the manual doesn't seem to be full time AWD. The manual also doesn't have the convenience of the variable road surface selector that the auto has.
As it turns out, I'm probably buying a set of snow tyres so that should give a massive increase in grip.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
