aiight i degreased and hosed down the engine bay and like a day later my car was like goin hell slow off turns and stuff and was making the BOP BOP BOP sounds from the exaust i danno what has happened...my mates dad said water has gone into the rocker cover and etc etc....but yea how to fix aye?
cheers
Chi
hahaha
if water has gotten under the rocker cover then it prob has been mixed with the oil. which is not a good thing. check the oil cap underneath to see if the oil has white blotches.
u havent put the hose in the exhaust to clean it out have u?
yeah i think its cause the spark plugs can't fire up completely...so therefor im loosing power....hehehe yea goin to get compressed air to blow the water outa it :) yea mate nah not that stupid to put my hose into the exaust haha im not that guy that put sand in his engine hahahahaha....yea hopefully everything is goin to be fine :D...but yea scared me like hell hahah i danno howd it got under the rocker cover aye, it doesn't look like it mixed with the oil tho but im still goin to do a oil/coolant change ye hahah
Cheers
Chi
Water = steam, obviously it won't be as bad because it's not coming out at a few litres a minute, but it could have the same effect. Personally I wouldn't take the risk with all the sensors & wires you can come across.
mmm i fixed my car and serviced it put mobil 1 fully synthetc oil in and new coolant and now it runs SO SMOOTH can't even hear the engine when idleing :whistling: hahah thanks dudes for the help yea the bop bop was gorn the spark plugs where having a bath in there heheh
normally the water doesn't get in due to my sealing ontop of the rocker cover was cracked/old it got it....its ok to high pressure blast it but just try to stay away from all the electricals but a rag and degreaser is best way i think
Cheers
Chi
I've had this happen to me before when I got the car detailed. They sprayed in the engine bay and got water in the plugs. It was a fun drive home :) ... after a few days of driving it was back to normal though. If I get the car detailed now, I specifically say to leave the engine bay alone. :(
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
