Lucky, very lucky - glad it was only the car that was hurt!
I know the tyres may have been a contributing factor - BUT PLEASE NOBODY USE CRUISE CONTROL WHEN IT’S WET/RAINING!
It's not a well known fact but many accidents happen with cruise control on in the rain, especially if the wheels aquaplane for even a second, the cruise can kick in and will just break traction, and put you and your passengers in a whole word of hurt. This info should be printed in cars that have cruise control – but it’s not. This needs to be general knowledge for anyone who drives a car – so tell those you know – TURN OFF THE CRUISE CONTROL IN THE RAIN OR WHEN IT’S WET!
Thanks for the well wishes everyone.
Im still a little ho hum about the falkens but there is very little info for SUV tyres. The load rating on STD tyres is the issue, im out of my knowledge base with SUV and 4WD tyres, Im still looking and doing my research.
Thanks
That's true. I have been in a near accident in the rain with cruise control on. I wasn't driving.
Oz: Glad to hear that you and your family are A-OK! That's what is most important in my opinion - cars can be fixed or re-purchased, life cannot!
Anyways, best of luck with the new ride, let us know how it goes!
good to hear u are ok, and good tyres are definetly worth the money for the rain, with crap tyres if anything goes wrong u have no chance.
Xinhua thats bad to hear too, what exactly was the damage? and was the damage from the kangaroo or the trees?
SiksII, every panel was damaged by the 20cm x 20 cm wood pools I hit, and the fence dragged accross the roof, bonnet and boot, to ensure everything was damaged.
I found the best way to get out of cruise control is to brake and then turn it off. If you turn it off it's like what ever throttle the cruise was at suddenly goes to 0%.
Glad you're ok though.
PS. What size are the stock terri rims? 5x114.3? Want to part with them?
IVe heard of similar stories with cruise control related crashes in the rain.
I did hear the technical reason why the car looses traction but I cant remember at the moment.
I read a similar story and the police attending the accident (it was a lady and she lived) blamed the cruise control and not neg driving or speeding.
When it is released I think a similar situation to what happens with compression locks as engine sometimes down shift. I think thats it.
Anyone know?
Glad to hear you and your family are ok mate.
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
