Hey Guys
I bought my r32 a few days ago and took it to my mechanic yesterday... he said everything is fine except the fact that my centre bearing (the big tube) needs some holder or somehting i had it writen on paper, and one of the fuel injectors is leaking fuel on engine!
How dangerous is this fuel leakeage and also how much are new ones. He said it'll cost around $150 for him to install it and roughly around $100 for injector but hes not sure for jap cars. Also, how much is the centre bearing support thing whatever its called? Where can i get these parts?
Thanks in advance!
https://www.sau.com.au/forums/topic/11450-fuel-injector-leaking-help/
You will probably find that the injector seal is the source of your leak not the injector itself. Not sure how they are set up on your car but on the RB26 it's an easy job to replace the seal - the seal itself should not cost any more than about $2!!!
Go to a place that just does fuel injection - I would be surpised if it costs you more than $50 to sort out:)
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
