im doing up my 1992 gts-t skyline so far i have put in a new engine it is out of an R34 its an RB25DET NEO i have a microteck computer,3 1/2 inch exaust from turbo back with a hiflowed cat,blitz bov,k&n pod,gizmo boost controller and alot of gauges and alot more mods i have 205 kw at the momint i still have alot to do as i wont to hit the 550bhp mark here are some pix of it for all of you to look at. thanks.
Edited by gts-t 4 life
https://www.sau.com.au/forums/topic/114505-update-on-my-r32/
i was giveing it a boot full when it happend went to change in to 3rd frm 2end at 80kph and it went bang lol
did not have the money to get the 33 box as the cheapest one i could find was for $1600 and need the car back on the road asap as i needed it for work so i had to get a 32 box got it for $700 so i was not complaining as my mechanic had it back on the road the verey next day (yaaaaa)
