im doing up my 1992 gts-t skyline so far i have put in a new engine it is out of an R34 its an RB25DET NEO i have a microteck computer,3 1/2 inch exaust from turbo back with a hiflowed cat,blitz bov,k&n pod,gizmo boost controller and alot of gauges and alot more mods i have 205 kw at the momint i still have alot to do as i wont to hit the 550bhp mark here are some pix of it for all of you to look at. thanks.
Edited by gts-t 4 life
https://www.sau.com.au/forums/topic/114505-update-on-my-r32/
i was giveing it a boot full when it happend went to change in to 3rd frm 2end at 80kph and it went bang lol
did not have the money to get the 33 box as the cheapest one i could find was for $1600 and need the car back on the road asap as i needed it for work so i had to get a 32 box got it for $700 so i was not complaining as my mechanic had it back on the road the verey next day (yaaaaa)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
