Hey all forum dwellers,
My car a black 2 door 1993 GTS-4 arrived a few weeks back now. I took delivery about two weeks ago now but have had no time to give it a wash BUT finally a free weekend and here are a few pics for you all to have a look at:
LINK TO IMAGES ON FLICKR And Atached...
Ok so hi everyone and I look forward to meeting everyone on a cruse coming up soonish
For those interested (everyone right) here are the current mods that came with my car from Japan:
Full turbo back exhaust (actually came with 3" straight pipe all the way back, this is now mufflered and "cated")
Pod Filter
Steering wheel
BOV
More to come.....
https://www.sau.com.au/forums/topic/114535-hi-everyone/
did you go through j-spec? looks like it from your avatar pic..
Nah Imports101 (Excellent Service, Recommended) actually. they all use Motorworld (correct me if im wrong here) so all the pics are taken at the same location in Japan. I think this is the reason for the pics looking the same...on just about all the importers sites.
Edited by johnn
https://www.sau.com.au/forums/topic/114535-hi-everyone/#findComment-2113331
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
