just wondering what peoples opinion in the best turbo for a 1/4 mile for street mods?
i know people pulling 300rwkw but they have pretty slow times compared to cars that are 250rwkw
most likely due to lag... but i was curious which turbo would be able to spool as quick to achieve the best 400m on the streets. i know bigger turbos mean more power but is it really usable for a quick thrashing on the road? safety... all those issues such as suspension... the works
i know that graphs can show a lot of power but what it doesnt tell is how quick does it achieve this power to be able to use this on road for traction on street?
https://www.sau.com.au/forums/topic/114538-what-is-the-best-turbo-for-14-mile/
Its not due to lag at all. Its due to car setup far more than power.
1) Traction is what makes your car fast (tyres/suspension)
2) Driver is what makes you car fast
3) Power is useless without 1&2 being sorted
Without the first 2 things down pat. The 3rd (power) makes little difference, its almost a hinderance in many cases.
I know using 330rwkw on street tyres. Best i could manage was a 12.1 with horrid wheelspin.
But i did run a 12.9 with approx 210rwkw, and using 225 street tyres :D
I had a reasonable 60ft of 2.0 and that got me the time.
The car was:
1) Setup well for the power
2) I could drive it well at that power
Putting down 330rwkw i had not raced it before, and the car certainly wasnt setup suspension/tyre wise to handle the extra power
And i get the impression your talking of street racing. Dont head down that line. That isnt tolerated on SAU.
cheers :)
type of car would be handy, otherwise we can't give you any feedback
also what times r u looking at? 11's, 10's or 9's? soo many variables so we really cant say X type of turbo would be the best for 1/4 mile runs
average power makes a car fast not max power
a car that makes a max of 250rwkw will have a higher average power than 300rwkw car. the 300rwkw will likely to have lots more lag, and it will be bog the dog or wheelspin city. the 250rwkw car will good average power and will be able to launch quite well with minimal lag
the car would be a skyline r33 s2... the last thing i would hate is to spend money on something that wont benefit me as much as the price tag on the turbo
r31nismoid i dont plan to drag on the streets, just wanted to know what turbo would be best suitable to the roads we all drive on everyday without losing traction and using the most power out of a turbo setup without having a huge lag monster
apexi powerfc + boost control kit
stock turbo
cold air intake
fmic
3" turbo back exhaust with split dump
some good 255 rear tyres
camber kit
castor kit
pineapple kit
get suspension tuned
Um, the best turbo for 400m on the street is no turbo because you are doing well over the speed limit in any state other than NT.
Big turboes aren't really that undrivable provided you have the traction available. You can chug around off boost in everyday traffic, but you know the power will come when you put the boot in. Also once you come on boost, it won't come off boost too quickly until you slow down again.
haha err whatever that means.... or is that just me?
this isnt answering your main question, but in terms of traction on the street, 300rwkw will always be difficult. If your car isnt setup well, it will be near impossible. My only experience with cars near that power was my old 180sx that had 280rwkw. That would sometimes wheelspin coming onto boost in 3rd gear, with pretty good tires, and coilovers.. Or you could take off from a standing start in 2nd gear, spinning all the way till around 100km/h ish.
As R31nismoid said, there a lot more things that come into doing quick times (quick is a more of a personal opinion anyway) than just power, or even smooth usable power... Its useless if you cant get it to the ground efficeintly.
- Also what kind of R33 do you have? How will you drive it on the street? And what is your idea of a quick time?
Edited by Cool Hand Luke
Okay maybe I didn't word that quite right. What I meant to say is that when you are thrashing around the racetrack *cough*hills*cough* you keep the rpm high, no lower than say 4000rpm at any one stage. So when you get back on it, you will have boost instantly. You don't have to worry about spooling up again. Or is this just an SR thing? Are the RBs different?
stock turbo
cold air intake
fmic
camber kit
castor kit
pineapple kit
spot on!
seen this done on a dvd to a GTR, guy ran high 11's... plus he had race fuel with a tune and more boost.
We are talking GTST not GTR arent we? RB25DET will make high 200 kw at tyres comfortably with stock internals and correct combination of bolt ons on pump fuel, which im sure has been well documented on this forum, as of choice of turbo, It depends on wether you are willing to upgrade other parts e.g exhaust manifold etc. GCG do a BB highflow which is good for around 230kw+ retaining standard manifold & plumbing, but will require ecu, injectors, fuel pump, boost control, to make that power. I personally like the GT 35/40 with ar.82 exhaust housing. I have a customer with this setup running mid 11s at 124mph on pump fuel, and car is very streetable, can drive it to the shops to get milk. but to run these numbers, you really have to be sixty footing around the 1.7sec mark, this is where your tyre and suspension will come into it as said in previous posts. nothing a set of MT 255 50/16 wont fix.
spot on!
