R33 S1 Turbo Upgrade
My friend has a R33 Series one skyline and is looking to upgrade to a T28 turbo.
-Is it hard to upgrade?
-What is an approx power gain?
-Will this require any more additional mods such as ECU, injectors etc, because he just wants to upgrade to a bigger turbo and push out about 300RWHP or more but not have to change the ecu etc...
thanks for your help guys
I say, how much does he want to spend?
Best mods power wise and cop wise on a stock car are roughly in this order: aftermarket ecu, exhaust, fuel pump, intercooler, turbo, clutch (moving up on your price range.)
Look into:
EMS Stinger 4420 or 8860
R33/R34 front mount intercooler kit
Skyline R33 BOV Adapter Kit
3-4 grand will get you a really nice set-up.
Edit R31Nismoid - this not a plug a business in every post you make forum.
Edited by R31Nismoid
Look into:
So tell me how a BOV is a performance upgrade?
Biggest waste of $100 i've seen short of getting drunk and throwing up in a nightclub
Also for the EMS band-aid... a PFC will do a better job everytime for the same
cheaper too if im not mistaken
that is the 2nd thread I've seen that posted in by nissanr33gtst..
what's the go..
you sell them or something?
and why would you recommend a bov adapter kit but no new bov?
I don't f*king get it..
edit..
bahahahahaha,.....
I just read the link..
A poorly made adapter may cause serious damage to the BOV and engine.
how the fluc can an adapter damage a bov or an engine?
$100
some things just rub me up the wrong way.....
edit again...
just realised your the same guy that just joined Fast Fours forum... giving the same EMS, and bov adapter advice there.
top work..
you'll go far.
Edited by GTST
your "friend" wants 300kW.. tell him get a T66 hhahahhh
umm he said 300rwhp
so thats 223rwkw ..
read better before you start laughing.
for that power .. 2530 turbo would be the best choice, along with power FC, and if wanna keep costs low install new fuel pump and an FPR to push the injectors a little more .. or just do it right and get bigger injectors
 Share
    • Anything for a 2003-2005 G35 will fit an M35. Just be mindful about clearance if you're running a plenum spacer or runner spacer.
    • You know how I know I'm getting old? Because I feel this quote jells with me and SAU Forums, ha ha ha. I've gotten lost a few times as I had muscle memory to scroll to where I wanted on my phone and just click, now I'm lost... Ha ha ha     "I used to be with ‘it’, but then they changed what ‘it’ was. Now what I’m with isn’t ‘it’ anymore and what’s ‘it’ seems weird and scary."
    • You don't lose spark if your battery isolator isn't wired correctly and the ECU still has power from the alternator.   Car has an epic wiring problem. Sounds like power connected really really badly in places. Possibly a power pin on a ground pin for the ECU, and constant power in locations that should be switched ignition.   It needs someone good at diagnosing electrical, a good multimeter, and someone with the wiring diagrams to match the engine loom that has been put into the car, and wiring diagrams for the body side of things from the car.
    • Hi folks, what options exist for PNM35 or what models share the same dimensions and fitment for the front top of tower strut brace. I have seen a few options pop up through Google, the Ultra Racing Australia for one. I have seen some eBay ones that claim they fit C34 and M35 but can't find details if to work out if its true. Also found Taiko / TEMA4x4 claim the one type fits: - Nissan Stagea (2-nd gen; M35) 2001 - 2007, - Nissan Skyline (V35, HV35, NV35, V35, PV35) 2001 - 2007 - Infiniti G35, G35X (3-rd gen; V35) 2002 - 2006 But not sure how true that is. Anyone fitted one or know of someone using one and can confirm what does fit?
    • I got the full kit.   The compressor as above is much smaller and lighter.  Also quieter. Bracket is visually mint and much lighter. The dryer and heat exchanger(rad) are one unit. Also smaller and lighter.  Much more room for an oil cooler. The fan I got was a bit Meh and I might change it.   And above all else it is more efficient, tested a good 3-4 degree's cooler than the old system, which is a lot. Disclaimer though - It wasn't a back to back test given different days. It really does feel colder though(always).  And this example is in my car with that crusty looking old compressor, not new vs new
