time for me to stop lending a car and start buying one
i've thought about my needs/wants in a car and in light of the recent fuel costs i'm going for something small, 4cyc. i hate bubble style cars (121's, Echo's etc) i want something small with a longer front and rear. i'd like something 2 door as well because i like the feel of driving one and i wont be driving anyone else around but myself. cost is a pretty big factor and i want something that holds value pretty well (all things considering) auto too as i will be in traffic jams etc and i only have an auto licence atm.
i was originally thinking a honda prelude (late 80's-early 90's) but hondas go bang after 220,00km and are really expensive for parts/fixing. great car when working though. i'm now thinking a mk5 toyota celica (90-93) being pretty much a 2 door camary must make getting parts easy (same engines as the apollo as well?) and there would be a wide range of people to service them.
has anyone here had experience owning a toyota celica of that age? how was it? any advice when looking for one? any suggetions for a similar car?
https://www.sau.com.au/forums/topic/114601-toyota-celica/
having driven/owned every model toyota known to mankind, I can tell you this much: it will not break down, ever. Nor will it be a rewarding or exciting driving experience, ever. As you said, they're a rebodied camry, and the camry was never designed to be a sportscar... and the celica was marketed primarily at female drivers who wanted a nice reliable car with a slightly sporty image. (hairdressers)
I bought one of these a few years ago (wrc edition) off an old lady... sold it to a young girl with big sunglasses and purple bits in her hair...
Get an mr2...
https://www.sau.com.au/forums/topic/114601-toyota-celica/#findComment-2110754
After just selling a 3sfe (2L economy engine) powered 1991 Celica, i can tell you it will never break down and be amazing on gas, but make sure its not a 4ws equipped model as that crapped out on mine. Also after just getting back from a month in Oz with my gf i noticed that all of that model Celica are badged SX? Im guessing they are 5sfe (2.2L economy engine) powered.
They may not be the most amazing driving experiance, but they are still fun.
https://www.sau.com.au/forums/topic/114601-toyota-celica/#findComment-2111092
Before i got my line i had a 93 celica sx, it was a manual series 2 (sunroof, fog lights are main additions)
anyway, i never had a problem with the car. i bought it in 2003 for 11grand with 160,000 on the clock and it went well for a 4cl. the SX is FWD 2.2 and i would recommend it highly.
has a relaible engine with a good gearbox (auto and manual) Being a toyota, parts are easy to come by.
the turning circle is crap though.
you could prob pick up an auto for 7 or 8 in decent condition.
Edited by PAV34
https://www.sau.com.au/forums/topic/114601-toyota-celica/#findComment-2111191
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
