Over the past 2 weeks it seems that my car has been loosing power, my car has been dynoed at 260rkws at 1.4 bar of boost. Car has been running fine for around 3 months now. Car is running a GCG Hi Flow and the usual other mods, FMIC, injectors, z32 AFM, etc.
Since Friday my car has been mis firing at high revs for some reason + the lost of power. I did run my car very low on fuel on thursday nite. So i put some injector cleaning in the car on saturday night with a new batch of fuel and it seemed to fix the problem for the night.
When i come on boost my car will blow some smoke and it seems that it could be oil or water. Running car off boost it is fine, no miss firing. Also my knock level is not going high. When it is mis firing it only reachs 25. No metal pieces in oil as well.
Things i have done:
Changed plugs - no difference to mis firing (BCPR6ES gapped at .7mm)
Injector cleaner - difference for one night only
Coil packs - have no cracks in them but have order splitfires which come in 2 weeks.
Checked oil no metal pieces and is pretty clean still like a month old
Still need to complete a compression test as well
What else could be causing the loss of power and blowing smoke?
Would this be something to do with the turbo blowing smoke?
Hopefully the splitfires will cure the mis firing situation but unsure about the blowing of smoke when coming onto boost
https://www.sau.com.au/forums/topic/114622-power-loss-and-blowing-smoke/
if the smoke it black then one or more of your cylinders arent firing so it could be anything related to your ignition (plugs, coil packs, injectors).. from what you've said it could be your coil packs.. in the meantime take your coil packs off and lightly sand the inside of them.. this part:
make sure it looks something like this when you're done:
its worth a try and it wont take much of your time.
i did this to my car when i had a misfire problem and it fixed it right up.
The colour of the smoke is more a white blue colour, which points towards oil, but it does leave a large amount of carbon on the back of my car. Could this be anything to do with the Turbo.
It only blows smoke when under boost so therefore it might not be the piston rings or anything since it not doing it all the time.
Will clean the coil packs up as above and see if that makes a difference.
Edited by z3n2k
blue smoke is never a good sign.. ever.
go get a compression/leak down test done to be sure. hoping its not something major wont stop it from being something major.
afraid so too. Do what SECUR1TY has mentioned and hope for the best.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
