Hi All,
Just wondering how many of yous out there have shift lights?
Im looking to get one for my 33 soon and was thinking about the Pivot SSL-M one..
Anyone owns this specific light? if so how do you rate it?
Be good to know what everyone has and what they think about it..
PS: Im looking for a really small one..
Cheers,
-JD
https://www.sau.com.au/forums/topic/114635-shift-light/
I did use a build-your-own jaycar model. It was pretty good and cheap enough. The good thing was that it was staged with three lights and also being only leds you can change them to any colour or intensity and also mount them just about anywhere to keep them stealth.
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2111791
you don't have eyes?
you have so much top-end torque that your tacho moves so fast you can't see it near redline?
seriously.. they're a wank unless you're a drag racer
+1
You could also add, "you don't have ears?" to that as well.
My car's got a shift light built in. I don't think I've ever actually used it.
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2113496
they are also used on circuit racing cars too..
you dont know what he is using it for so ease up.
plus it helps some of us that do have the issue of the tacho moving to quick to read it up there.. the joys of lag then wheelspin...
Alan, you might not "use it" but i bet you notice it, just never rely on it to make a change.. the subconcious is a handy tool.
meh
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2113564
Where its situated, you can't see it during the day because its not bright enough to show up.
At night you can make it out, out of the corner of your eye. Its possible I subconsciously use it, but I rarely ever see it so I'm not entirely sure I do.
I am tempted to install programmable shift lights in the car. The only thing I want the shift light to tell me is when to downshift when braking so I don't over-rev the engine. There have been a couple of times where I've downshifted too early on the track, and put the needle into the redline.
Edited by scathing
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2113875
I've got a T-sport shift light:
http://www.tekniqauto.com/CDN/tsport/tsport.htm
6 LEDs that light up sequentially - but the main thing that appealed to me about it is how inconspicuous and slimline it is...not a massive cluster of lights in your face :(
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2114047
a good driver and a good owner knows exactly what RPM's his or her car is doing just from listening to it. im not that saying that you are bad drivers for using one, but seriously, unless you have a high powered race car or drag car, you really shouldn't need one. most lower catergory of race cars dont use them, as it a good way to teach the driver about their car, by using their ears and the feedback from the car rather being told when to do it by an automated sequence of light(s).
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2114839
I'm with Craved on this one, shift lights can be useful. 4000rpm and nothing but wheelspin does mean that the tacho needle moves to 8000rpm faster than anyone could see.
i understand where your coming from on this, but still, i bet the majority of 'lines out there are rev limited. and the ones that aren't (mine included...) just have to be careful and use some throttle control. i regularly put my beast on the track and even when drifting out the corners, i still manage to keep it under the redline. i'd be lieing if i said that i haven't had my car over 7,000 RPM, cause i have, but because i take excellent care of the motor, i dont worry so much when it happens....
look in the end, were all different. if you feel the need to buy a shift light, then do it. im just enjoying having a friendly discussion about a topic which has so many sides to it..... :huh:
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2115158
Just out of curiosity, since I've never owned a car that had enough power to wheelspin indefinitely, if you're wheelspinning do you hold that gear until the rear eventually hooks up so your ground speed matches your engine speed (given the gear you're in), or do you change gear?
I mean, if you're wheelspinning then technically you're banging off the rev limiter but your actual velocity isn't equal to if you were redlining your engine with traction. This means if you shift, then you might fall out of the meat of your torque / boost curve.
In all of my (underpowered) machines, if I've ever broken traction I've just backed it off a little or held it on the limiter until the car's speed has eventually increased to a point where the tyres get traction back.
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2115737
I think you've answered your own question... :angry:
https://www.sau.com.au/forums/topic/114635-shift-light/#findComment-2116087
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
