Im not familiar with the plazmaman plenum physically, but before it was bolted up did you put a straight edge over the plenum base where it bolts to the runners to make sure its perfectly flat.
I know on some plenums when they are welded the base warps and if the base isn't machined perfectly flat, it will never seal, even with a gasket.
I doubt this is the issue with such a nice plenum, however some things need be checked when looking for those illusive bugs and gremlins.
I will have a look in the manual for what pin number the TPS wires are a little later tuna_144.
yeah these aren't welded, but they tap studs into them.. but there is a spacer at the bottom of the plenum to raise it like the std one, so not metal on metal.. there is about 3mm
i think ones of these is wrong and not clamping down close enough to the runners flange..
will see how it goes,
carby cleaner does show the leak with the car revving up a little. but is audible when quickly opening the throttle.. bit of hessitation on the road when it does it.
Put some soapy water in a spray bottle and spray it around the plenum base while the car is running. Open the throttle slightly and look for evidence of air leaking: Ie bubbles.
Plazma man plenum has recieved alot of good feedback. If you used the appropriate gasket, I doubt this would be the source of your problems.
Hi Plazmaman here ,
The whole system was designed as per Nissan factory specs. Nissan factory did not use any sealant on there factory gaskets . We recommend a sealant (threebond) on the gasket - it is a must for high boost applications .
Also check initial gasket thickness , might be a hole in the side .
We will be happy to assist , we have a large team that is willing to help you with any problems relating to our range of products . Any dramas please contact us 02 9725 1728 .
We have never had a problem to date .
Hi Plazmaman here ,
so a sealant over the factory gasket to assist it to seal. im willing to give it a go.. was thinking this would be the only way around it other than running a shim in there to decrease the gap.
Yeah i'm pretty sure its not a vacuum leak. Will get checked again at Desynz this friday, and getting him to look at the IAC and install my new speedo sensor.
Excellent plenums you guys make btw, am very happy with it. Its always the first thing people notice and ask about when i pop the hood :cheers:
What do you recommend to keep the mirror finish though? I tried some of that Autosol metal polish and it helped a bit, just after some suggestions, and I guess the person who made it would be best to ask.
Cheers
Polish plenum using MOTHERS mag and aluminium polish . Small circles using a quality polishing cloth we found is the best way . Other polishes are scratchy and dull up after a while .
Our instruction leaflet with the plenum stated to use sealant . If you havent ,that is definately the problem .
Also idle speed motor do get clogged with soot and carbon - maybe clean and blow with air hose .
We have had news today that a customer has made 695 Rear wheel hp with one of our plenum / swept back kits on their car . We will hear more shortly . We are proud that our products make big reliable horsepower .
i was having idle problems so i went and saw my mechanic friend. He told me to get this stuff from the Subaru Dealer which is a Upper Engine Cleaner. You spray it into a vaccum line in the plenium then do what it says. it clears out all the carbon build up and junk. I also added in some Nulon Trade Strength injector Cleaner. Useing the both of these my car runs much much better while driving and goes seems to have heaps more power and the idle does not hunt any more. The stalling side of it he rekons is the idle control sensor which apparently with shit fuel we have around here chokes it up. How true is all this? Must have some trueness to it as my car is running heaps better since i didd this at the cost of all about $25.
Alex,
have you tested these plenums on the R34 GTT runners? do they fit?
think i put the instructions down after having to drill out the std bolt locations on the lower section to be able to fit the studs through .. oh well
will try the sealant on the gasket and see if she gets fixed up :)
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
