Item: Nissan S12 Gazelle
Website: None
Reason for Selling: Moving onto bigger and better
Price and Payment Conditions: $7000
Extra Info:
Engine:
#RB20DET silver top
#HKS 25/30 turbo
#Hybrid FMIC, mandrel bent aluminum plumbing
#K&N filter
#3inch exhaust from turbo back, cannon muffler
#Customer PWR cross flow radiator with header tank
#Walbro 550hp in-tank pump
Driveline:
#R32 GTS-t 5speed manual
#NPC heavy duty 3200lbs organic clutch
#Custom 1 piece tailshaft
#Gtir LSD installed
#Tomei short shifter
#Volk 16x7 and 16x8 wheels (small dish)
Brakes & Suspension
#Power steering
#R32 GTS-t 4 piston brakes
#S13 front lower control arms
#S13 front hubs
#S13 JIC front coilovers (rebuilt)
#Kmac Z31 rear springs (300lbs 70mm lowered)
#Es9000 hilux 4x4 rear shocks
#Adjustable castor rods
#Cefiro front sway bar
#Poly rear subfame bushes
#Poly rear control arm bushes
#Poly castor rod bushes
#Poly front control arm bushes
#Customer rear subframe capable of 0deg camber with lowered springs
Interior:
#Jap drift steering wheel (white with green glitter)
#Alloy shift knob
#Jbl speakers
#Battery mounted in boot
Pictures: Will get more pictures on request
Contact Details: Post here or call 0403 373 911
Email: [email protected]
post-103-1145777517130191429.jpgpost-103-11457775481003077327.jpgpost-103-1145777579535867952.jpg
https://www.sau.com.au/forums/topic/114651-rb20det-s12-bne/
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
