  • Replies 179
Nice,What Turbos are you using this time?
The factory heat shields look good ceramic coated ,did you do yours?
HKS GT-RS....BTW the ceramic coating is done to keep the heat in the system (turbine side) and is not there to protect other items...thats the job of heat shields. The compressor side is done in ceramic chrome for asthetics as well as keeping the heat from transferring into that side of the system. Heat shields are used and are chromed.(again for bling!!!)
Edited by DiRTgarage
Cool,Only problem you'll face is wild comp serge with the GTR-S turbos.
Ive never sorted it so let us know how you go with yours.
No problem when you run WOT.....wide open throttle...lol
Jim's a great tuner though and tuned all shuffle out of the system with the 2530's. Ive really handed him a task with the RS's...lets see if he's up to it.
Looking good. Any diference between the black and silver ceramic coatings?
I think from memory the silver is a single coating rated to 700deg and the black is a double coating rated to 1100deg. The black works so well the turbine housing can be touched after racing without burning your fingers.
I thought when using GTRS turbos it was best to have the mainfolds with a cross flow pipe? Think that was what mark34gtr said about his GTRS setup.
Brad
Yes Brad, the balance pipe helps in street cars for drivability.....which is something i dont give a toss about. This setup is all about full noise low 10 to high 9 sec passes....nothing more.
You are seriously kidding me? It is THAT effective? Amazing!
And ask a stupid question, wtf does RH9 mean???
RH9 is an accreditation given to Japanese workshops that builds 9 sec GTR drag cars that run "street" tyres. Its like a club i suppose...a 9sec street GTR club. Contrary to popular belief the workshops are recognised not the car itself. There are 5 RH9 workshops in Aust....BSM, Godzilla Motorsport, Tillbrook's, Croydon's and Willall. DiRTgarage hope to become the 6th.....but more importantly.....to our knowledge no-one has done this using low-mounts.....we hope to be the 1st.
Hi,
Looks good :)
Was this done by "Competition Engineering" in Guildford?
Did they coat the inside of the exhaust manifolds? If so, are you/they worried about bits of ceramic coat going through the turbos?
Regards,
Saliya
Yes, Competition Coatings at Guildford.
Only the external surfaces look to have been treated.....but in saying that.....its quite common to get pistons coated.....so the product must be safe to use
Looks good Paul and Stace :)
did you get the fruit bowl done to match?? ;)
cant wait to hear how the two of you go once its all bolted up and tuned..
all the best :P
Thanks mate...
yes the fruit bowl is subjected to extreme heat from the in floor heating....so we had it done too...lol
wont be long now....bolting it all up this week.....tuning the following Friday if all goes well.
Thanks mate...
i loved that infloor heating .. i want it :P
awesome news that its so close.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
