  • Replies 179
Instal finished, drove it to the workshop yesterday to pull the clutch out (it was heavily punished) its and packed ready for its trip to Jim Berry for a reco. Should have it back in and down at Croydon's this coming Saturday.
here are my goods paul
very nice
John, the inside flange of the turbine housing may need the coating removed (we did ours with a razor blade) so they assemble correctly. Its the inside surface where the core meets the turbine. Any probs or questions mate give me a pm.
"John, the inside flange of the turbine housing may need the coating removed (we did ours with a razor blade) so they assemble correctly."
"We" as in Ben! did it.
ha ha
Yes Ben you had a little scrape i must admit....but "all" of it needed removing. Thanks for your input.
So yes..."WE"...."Ben and I" removed it.
Edited by DiRTgarage
Guest Mashrock
Looking good! good luck with the 9! i'm glad to see people pushing their gtr's
hope it all goes well.
and what kinda of drop in inlet temps should you be expecting with all the coatings done?
might be worth a shot for my setup.
and do you happen to run a vented hood?
Edited by Mashrock
Thanks Mashrock for the support.
The real gain for the coating is on the turbine side holding the heat in, this aids in gas velocity and flow. The gains on the inlet (we have not done this side of the system before) are yet to be seen. But we use a very accurate Carel temp. meter to monitor plenunm temps, so the real world gains will be seen after full load tuning and full noise passes are completed. I must admit i only really got the inlet side done to tidy up the pipework and Rob was giving me a bit of a discount to cover the additional cost.
I dont run a vented hood as the temps during a run do not warrant it, Mark Jacobsen weighed his and its heavier than a stocker.
Guest Mashrock
ahh i see,
yeah i guess your only really having the car on for no more than a minute for the time you really need to make the numbers,
i'm cutting a big hole in my hood very soon and throwing in a massive vent moulded off kris's mines gtr. but thats for circuit, a friend saw atleast 15-25 degrees less engine bay temp. so it seems like it would be worth it.
I can understand the need for an accurate inlet temp sensor. After my upgrade I was horified to see that my inlet temps (showing on the PFC) were consistantly around 25C higher than ambient (50C on a 25C day). What I did notice, however, is that the IC outlet was cold/ambient to touch and that the inlet temperature readings on the PFC hardly varied.
In reality I suspect that what I'm really measuring is the temperature of the plenum wall (nicely heated by the engine radiant heat) rather than the intercooled air passing throuh it.
Where do you place the aftermarket inlet temp probe?
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
