my 4WD light comes on every now and then when i start the car, although all i have to do is turn it off then on again and it goes away. By the way, the car loves to get sideways when the light is on... good old RWD :whistling::):P
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111319
yeah ive tryed that and it stays on all the time. wen it hits boost it really goes sideways
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111333
Doesnt say what the abnormality is - it's just a warning. As per Andy's post it obviously stops working otherwise he wouldnt get it so easily sideways in the dirt.
As the car is constant AWD there is no switch to turn it off or on. except for the synxchro (S) button which I believe acts more like a central diff lock. Which is why the steering gets heavy on full lock when synchro is activated.
Not that I know any of this by expereienxce as mine is 2WD only.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111376
abnormality? like...?
not operating correctly, low attessa fluid maybe (in the boot) ??? dodgy wiring, stuffed attessa pump, or anything related with the attessa stuff, try accessing the attessa ecu in the boot as per another post i showed pics of where its located and read the diagnostic light sequence and check it up on the workshop manual for what is the problem.
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111380
i have mine come on every now and then, when it does, i just turn the car off and on.
I also had it come on once because i didnt put the plug back right into the ecu and one end was being held up.
also, i got it when i disconnected the vac line on the bov for some flutter, car stalled and then the 4wd light would come on every now and then along with the car driving like poo. It went away after a while, guess the ECU taught itself.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111459
Who said anything about being in the dirt? :):(:bunny:
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2111701
Please dont ask for manuals.
Other than that, I dont have a 4WD light, mines a HICAS light, same thing as I have a 260RS dash, and mine never comes on, only when the key is in the ON position but not actually started the car....?
But all that said, Brad is spot on, check fluid levels and/or attessa system!
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2117873
4wd light on all the time = not bled or no fluid...if it goes sideways, its prolly not working, check the resovoiur in the boot and see if both the top and bottom tank is full? and maybe bleed the system too...might fix ur problem...but my light stayed on when i put my engine back in last week until i bled the system out :D
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2117928
the tank is full, but ive been told that theres a earth wire in the engine bay for the atessa system, so they might of removed it so im goin on a hunt when it stops raining over here lol
ska - sweet as dude i wont
Edited by gzzmos
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2118106
WHAT DO YOU MEAN BY DONT ASK FOR MANUALS ????????????????????????????I DONT GET YOU GUYS .ITS OK FOR FUNKY TO SELL EM SORTA BUT NOBODY ELSE IS ALOWD TO SHARE .......
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2118116
There is a $189 / 491 page R33 Service Manual, I think thats the one they mean. There 'was' once a link to it for a downloadable PDF file of it, but thats been shutdown. Im pretty sure JPNZ own the rights to this translated manual, and therefore it breaches copyright if it is 'exchanged' between ppl wiothout $$ rights going to JPNZ.
I dont know how Funky has gotten around all that, maybe becasue his manuals are in Japanese writting and the local Japanese copyright may not be applicable in Australia, whereas JPNZ is a New Zealand company who translated this Japanese manual, and being based in NZ therefore AUS laws apply.
Hope that helps! I was lucky enough to come across the service manual in pdf format (via GOOGLE, hahahaha) just before the webpage was shutdown. I saved it to disk and have not reproduced it in any way shape or form. Lately I have been asked a lot if I can forward this pdf.file onto ppl.........
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2118157
My manual came with the car - its a JPNZ one, but only 258 pages. An abbreviated version like the type you normally would get in any jap car that tells you every useless bit of info about how to turn lights on and off and how to drive the car up and down hills. But never contains anything mildly important if you want to fix something - standard reply is, "if in need of servicing please refer to your nearest Nissan dealer."
All that aside, it did have extra info on the 4WD light dilema. And I qoute:
The 4WD light will illuminate when the ignition is turned ON and it will turn off when the engine is running.
When the 4WD warning lights shows or will not illuminate when the ignition is ON, have your vehicle checked by your Nissan dealer as soon as possible (told you it was helpful)
If the warning light flashes check that all tyres are the same size and brand (This includes air pressure) If the light continues to flash, then (you guessed it) have it checked by your Nissan....
If the light turns on when driving, the ATTESA system will cease functioning but normal driving will be possible.
The 2nd last point makes sense - if the tyres are rotating at different speeds then the ATTESA isnt going to engage because it will be fighting against itself like trying to engage two gears at once, so it will opt out and not engage at all, hence the warning light.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-2119084
  • 16 years later...
So light could be on because of uneven tyre pressure? Would that apply to just the rear tyres though.
https://www.sau.com.au/forums/topic/114654-4wd-light-on/#findComment-7968167
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
