Some of you may know I've been trying to sell my cef for ages now and because it's a drift car it's probably a limited market. Someone who wanted a street car could just repair the bar and whack on a decent paint job and they'd have a fat car but all the people who are interested in it want to either swap their car or have no money.
My question is since many people have purchased imports then decide they want to get into drift, what does everyone think of my chances of swapping my car for say a r33, then selling the r33?
I realise it'd be easier if the person who was interested in my car first sold their car, but the reality is I might be willing to drop the extra 1-2k on the r33 because it's worth to me to get rid of it.. whereas they might want to wait to get the price that they really want.
Also, this way I hope to widen my chances of getting money to pay off my debts because the market widens up.
So... does anyone have any coomments on the advantages/disadvantages of this approach (other than getting stuck with a whale-33 haha), and also what is the price range of stock r33s these days? I'm thinking around the 15k mark?...
Finally, does it make any different to price for which series of whale it is?
https://www.sau.com.au/forums/topic/114710-r33-market-at-the-moment/
CC,
if your going to swap it go for a '96/'97/'98 SII.. wouldn't go near a SI now as they are pushing 10/11+ min years.. that's just my thoughts..
As for value - a '96 R33 could fetch from 16k - 19k depending on what kind of condition it is and depending on what the market is like at the time..
Personally - with the way fuel costs are going you could be holding onto a R33 for a while if you have a set price in mind.. also mods won't count for much value - people will pay maybe a little more for it - or they'd rather a stock one as it may not have been flogged quite as hard..
Make sure your not getting a lemon :sick: why are they swapping - they want a drift car? compression test.. the usual as you know..
sale price for R33 SII >16k+.. also - how many km's has it got? are they legit?
Your selling your ceffie for 16K - you reckon you'll get much more than that for a 33??
Edited by Links
Hey Links,
Thanks for the info. I see a few goin for 12k now too (S1 etc).
I don't want to make money on it it just seems that a lot of people interested in my car don't have money or have another car. It's actually quite amazing, people have been breaking my balls over the price too and I can understand they'd like a bargain but it's starting to get quite sad.
I thought what I'd do is widen my market by trading someone who is into the drift thing for a car I can recoup my money with in the hi-po import market.
Time will tell how I go.. I don't really want a whale and the cars that are like are boro lookin 86's, a31's and c33's haha
R33s are indeed becoming more popular. IMO, the RB engines are pretty realiable and people became more aware of them. Some of the series 2s are going for as low as $16k, some as high as $23k for a well modded one.
In japan, the skylines are coming out of the auction houses at a relatively low price too.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
