yes - doesn't fit directly on to an RB20
yes - would cost more to fit than it's worth.
but my question is this.
why is it that an SR20 in an S15 can pull 220rwkw with stock turbo by changing almost everything else like cams, cam gears, ecu, and all supporting mods to run this turbo at about 17-18 psi boost, but same can't be done using this turbo on an RB20?
do any of you peeps know the specs of an S15 turbo?
If I recal it is supposed to be a 320hp turbo (or was it 280)...
anyway, let say for example, you bought this turbo and it came already bolted to an aftermarket RB manifold with all required lines for oil and water and dump pipe to fit directly on to your rb20.
what would be required to make the same 220rwkw out of it?
would it make it?
would it require more boost in the RB than it does in the SR?
I'd guess that the rb's lower compression would need attention.
DISCLAMER: this is purely hyperthetical.
no need to come on here to say things like why would you bother and so forth.
I am looking for technical responces to explain if it can be done and what it would require.
https://www.sau.com.au/forums/topic/114711-s15-turbo-discussion/
  • Replies 44
Posted Images
Id say part of the reason is the fact that the Silvia turbos dont use ceramic exhaust wheels.
And because of that an RB20 with an S15 turbo wont make the same power??? No one is watching you, you can read the first post a number of times without anyone thining you are daft. But once you hit reply its all over!
Dont the later model SR20s have vvt on them? Would this not help, along with however many extra years of development.
id say that its because the engines probably abit more eficent. besides a stock 20 turbo is nothing special
also i believe rb20's are alot more suseptable to detonation problems once pushed. so you cant run a whole lot of timing thru them
LOL..
I was under the impression that the VVT on the S14 and 15 sr20's were only good for low down grunt.
I just assumed that by using 7psi in stock trim to put out about 100-110rwkw and being able to get that to 220rwkw using same turbo, 2.5 times more boost, and other mods, would the same said mods produce same numbers when used on an Rb20?
I guess I was trying to find out if the S15 turbo when implemented on an RB20, can produce sr20 style numbers.
or is the turbo just designed right for the sr20 and won't do the same on the rb20?
it comes down to displacement and how the engine makes power.
youll also find the sr20's are somewhat less laggier compared to the rb equivalent when talking about turbocharger response. i think they also run split pulse manifold and housing from factory.
I reckon if an RB20DET was developed to make the same type power as a std or mild SR20DET it could do it . If it was sized to run out of air and exhaust flow at the same point that is . The thing is who's going to put 9:1 pistons along with porting /cams/ turbo etc to make SR20 type torque for their Skyline ?
You don't need to anyway because an R32 looks much faster parked in the street than any Silvia .....
im going to get flamed for this one but the sr20 is a better engine. it has vvt, a higher compression ratio, heaps more torque so rightfully produces more power. it takes a heap of supporting mods to get a t28bb up to 220rwkws however. (i also own an s14k's so know a little about them)
realistically you would only expect 200kws atw on an sr vvt engine that doesnt have things like exhaust manifold, upgraded afm, cams etc etc
if you think about it the rb26 is nissans flagship 6 cylinder engine whereas the sr is their flagship 4 cylinder engine. building the rb20 better than the sr doesnt make sense from a marketing prospective.
I'd say that the RB20 would make a little less power than the SR20, if using a S15 turbo
SR20 has much better head flow, higher comp ratio
RB20 'could' rev more, but not with that turbo, as its very similar to my 2510 and that runs out at 6500rpm. After that it feels flat.
I'd chalk up a win for the SR20
hehe miss the cefiro :sick:
I had 195 with 14psi and 204rwkw with 17psi (never ran that due to ceramic wheel)
but i had a list of supporting mods as long as my arm...
I rate the RB25 as a great turbo have just bolted one to a vg20det and am getting a little more than 200 with it and lots of methanol/water.
sorry off topic :ermm:
I think the RB25 turbo will produce 10rwkw less than the S15 turbo on any given RB20
That is if you did a power run with the rb25 turb, swapped the s15 turbo on with an adapter and did another power run.
VVT on the S14's and S15's only really help with better fuel economy. The reason a Sr has more torque is because its a over square motor and has a faily big capacity for a 4 banger.
RB20's are notorious for being breathless down low its due to being a small displacement 6 cylinder. I actually believe the CA is a better built motor then the SR. Its internally stronger and shares many similarities to RB26's. There downfall is age though.
My 2 cents
Chris
Its called contributing to what you know and learning my friend thats how forums work. Havent you heard the old rule if you dont ask questions and comment you will never know the answer.
So given that, and say the engine is stock internally the RB20s will be older most of the time. There is bugger all in it I would think.
You need to remember, turbo sizing and cam specs aside.
The 2L SR20 has the same displacment as the RB20, therefore all things being equal it will have the same total airflow as the RB20.
However the thing you need to remember is that the SR20 only has 4 pistons, so less pistons, less valvetrain componentry, less main bearings all equals less friction and reduced pumping losses.
So its means the SR20 in theory is going to be alot more efficient at making its power, with less places for loss of power to occur.
Thats my 2c anyway...
Edited by RB30-POWER
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
