Could be two things
- Regulator
- Power window motor
Not sure about regulator but a non genuine window motor will set you back $150 from http://www.justjap.com
Thanks Wink -Is it a job i can do myself, or does it need to be taken in?
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2112686
you'd be supprised that it might actually be the connections on the ectual window switch itself
mine died too and it was a case of remove switch, unsolder everything, clean it will electircal contact cleaner, and resolder the wires back in
-Ruffels
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2112989
If you have time just try to swap one from a mate with the same car and troubleshoot which part is actually dead.
If it's just struggling to wind properly some silicone lube sprayed on the car door/window rubber to make it easier works wonders. Remember to wipe the window clean after this though otherwise you get oily windows. ... By the sounds of it though it's probably the motor or reg.
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2117024
hey, mine's not working either but for a totally different reason, i hand my 33 resprayed and the painters took the door off and broke lose 5(that i can see) wires, i have ni idea what they plug into, has anyone or can someone please take some photo's of the drivers door with the door card off please, some nice close ups of the wires would be great
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2137567
i think sometimes the relay switch doesnt turn off straight away when u auto wind up hence burning the motor out earlier. thats why i dont use auto up anymore :P
its a prety easy job to replace if u know what ur doing. i learnt the hard way. all u have to do is unbolt 3 bolts that hold the motor to the bracket take it out and whack the new one in all with the window up and intacked. no need to take the complete arm assembly out. now getting to the 3 bolts thats another story. a small prison mirrow and a miners spotlight will help..lol. sholdnt take you more than 30mins if u do it right.
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2142498
  • 4 weeks later...
Where does the switch connect to? I took the switch out yesterday, all looked clean, and when i pressed it i could hear something further back in the door click.
I'm having the same problem at the moment with my R32 GT-R. After taking the door panel off I've figured its the power window amplifier that's stuffed. It's the little black box bolted onto the door with 2 screws.
It makes a click everytime I flick the switch. With the door apart and me fiddling with it, I can make the window work, but everytime I start to put the door back together and test it, it decides not to work again.
Has anyone fixed a power window amplifier? Or should it just be replaced. If so where could I source one and how much $$$?
Thanks
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2206448
The black box thats clicking will most likely be a relay for the window motor. If its clicking its probably still working, as the clicking you hear is the switch in the relay working. They are a silly/complex setup in the skylines so far as window operation goes. If you have a problem with it it would be best to remove the regulator assembly fixed with 4 bolts/nuts (if i remember correctly) and test it outside the car. This way you can make sure everything is working correctly. Or what is not :sweat:
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2206656
  • 4 months later...
Hey Guys,
The Auto-Up and Down functions are what burns out motors. I have read a few threads on this already and it seems to be the case for a few people. When the window is motoring up and down in auto mode, and the maximum excursion is reached (ie, it hits the stops top or bottom) resistance builds up from the motor, this will cause a spike in the amps being drawn and the smarts inside the curcuit will cut the power to the motor. My 33 has a problem with the switch because it is all floppy when you press down on it, and will stay down and not actually release properly even though I think it has. Needed to listen to the clicks audible from the relays in the regulator to eventually work that out
The smarts in the circuit do not appear to be set out in a logical way that cuts power to the window motors in the first (pre-auto) position and this has been burning out my motors. I have already gone through 3 replacement motors.
I have a EF Fairmont with a similar problem. The switch sticks when it auto-downs and I forget about it, the window stays down and wont raise again. But there is a safty circuit built in which resets itself when the car is switched on then off again. Geez, evan my dad has a 1978 Rolls Royce Silver Shadow II with power windows, and it also has a reset circuit behind the glovebox with a button you press in the event a passenger leans on the switch for too long.
I really wonder why Nissan just didnt put a fuse or something in there somewhere? I hate to think I am going to need a fourth motor again.
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2612174
    • Is anyone running these axles? R32, R33, R34 GTR front Axles. shafts itself rated 950hp. Suit all RB26 engines Croydon, Melbourne, Victoria Would be nice to pay half the cost of Driveshaft Shop Axles. I'm building an AWD S13 Coupe that is very low ride height (high cv angle) compared to stock R32. Has an RB30 with appx 600whp. Just looking for feedback. Thanks, Josh- https://www.instagram.com/feng_shui_garage/
    • Been a long time since r31 got some love, my brother dropped a shitbox ls1 crapadore in my lap to fix up.  Put a wiper motor in as the flooded one was no longer alive.  got windscreen wipers now. Time to clean respray and install back in the titanic  IMG_0505.mov
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
