Could be two things
- Regulator
- Power window motor
Not sure about regulator but a non genuine window motor will set you back $150 from http://www.justjap.com
Thanks Wink -Is it a job i can do myself, or does it need to be taken in?
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2112686
you'd be supprised that it might actually be the connections on the ectual window switch itself
mine died too and it was a case of remove switch, unsolder everything, clean it will electircal contact cleaner, and resolder the wires back in
-Ruffels
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2112989
If you have time just try to swap one from a mate with the same car and troubleshoot which part is actually dead.
If it's just struggling to wind properly some silicone lube sprayed on the car door/window rubber to make it easier works wonders. Remember to wipe the window clean after this though otherwise you get oily windows. ... By the sounds of it though it's probably the motor or reg.
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2117024
hey, mine's not working either but for a totally different reason, i hand my 33 resprayed and the painters took the door off and broke lose 5(that i can see) wires, i have ni idea what they plug into, has anyone or can someone please take some photo's of the drivers door with the door card off please, some nice close ups of the wires would be great
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2137567
i think sometimes the relay switch doesnt turn off straight away when u auto wind up hence burning the motor out earlier. thats why i dont use auto up anymore :P
its a prety easy job to replace if u know what ur doing. i learnt the hard way. all u have to do is unbolt 3 bolts that hold the motor to the bracket take it out and whack the new one in all with the window up and intacked. no need to take the complete arm assembly out. now getting to the 3 bolts thats another story. a small prison mirrow and a miners spotlight will help..lol. sholdnt take you more than 30mins if u do it right.
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2142498
  • 4 weeks later...
Where does the switch connect to? I took the switch out yesterday, all looked clean, and when i pressed it i could hear something further back in the door click.
I'm having the same problem at the moment with my R32 GT-R. After taking the door panel off I've figured its the power window amplifier that's stuffed. It's the little black box bolted onto the door with 2 screws.
It makes a click everytime I flick the switch. With the door apart and me fiddling with it, I can make the window work, but everytime I start to put the door back together and test it, it decides not to work again.
Has anyone fixed a power window amplifier? Or should it just be replaced. If so where could I source one and how much $$$?
Thanks
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2206448
The black box thats clicking will most likely be a relay for the window motor. If its clicking its probably still working, as the clicking you hear is the switch in the relay working. They are a silly/complex setup in the skylines so far as window operation goes. If you have a problem with it it would be best to remove the regulator assembly fixed with 4 bolts/nuts (if i remember correctly) and test it outside the car. This way you can make sure everything is working correctly. Or what is not :sweat:
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2206656
  • 4 months later...
Hey Guys,
The Auto-Up and Down functions are what burns out motors. I have read a few threads on this already and it seems to be the case for a few people. When the window is motoring up and down in auto mode, and the maximum excursion is reached (ie, it hits the stops top or bottom) resistance builds up from the motor, this will cause a spike in the amps being drawn and the smarts inside the curcuit will cut the power to the motor. My 33 has a problem with the switch because it is all floppy when you press down on it, and will stay down and not actually release properly even though I think it has. Needed to listen to the clicks audible from the relays in the regulator to eventually work that out
The smarts in the circuit do not appear to be set out in a logical way that cuts power to the window motors in the first (pre-auto) position and this has been burning out my motors. I have already gone through 3 replacement motors.
I have a EF Fairmont with a similar problem. The switch sticks when it auto-downs and I forget about it, the window stays down and wont raise again. But there is a safty circuit built in which resets itself when the car is switched on then off again. Geez, evan my dad has a 1978 Rolls Royce Silver Shadow II with power windows, and it also has a reset circuit behind the glovebox with a button you press in the event a passenger leans on the switch for too long.
I really wonder why Nissan just didnt put a fuse or something in there somewhere? I hate to think I am going to need a fourth motor again.
https://www.sau.com.au/forums/topic/114717-power-window/#findComment-2612174
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
