Hey all,
First off I'll start by saying I'll never try to replace the clutch on my R32 on the ground again :) But now that I'm halfway through, I guess I need to go through with it. I got all the bolts out and check and double checked everything was loose and taken off but I just can't find a technique to twist the gearbox to clear the firewall. Has anyone removed a R32 or R33 manual gearbox before? Do you need to do anything stupid like angle the motor to pull it out? Or have the gearbox hanging down as far to the ground as possible or pushed up as far as possible? Just that I'm really stuck and can't figure how to pull it out.
Thanks,
just pull the f**k out of it.. it may take some heavy pulling to 'pop' it out of the spigot..
you could also (if you have another one) try jacking the front of the motor up a little, to angle the box downward a bit.
You did remove the shifter from up top right?
Ive removed a r32 gearbox out of my r32, and put in and removed a r33 box in my r32 on the ground.
They require a twist to the passenger side as you pull it out to clear the starter mount on the firewall. It should come out easy.
take out the shifter as Pred has said...waaay easier :D
Yup the shifter is all pulled out and everything. So putting a jack on the front of the motor should help clear the firewall by putting it on an angle? And I should turn the gearbox anti-clockwise (looking from the rear of the car) so that the bell housing clears the firewall? The car is on 4 jacks at the moment and I'm pretty sure the front is sitting higher than the rear, so that probably doesnt help either.
U dont need to jack the motor at all really. Just lift the box slightly as you pull it to the rear. When it separates from the motor slightly then u should see what needs to be done to get it out.
Remove the clutch slave too :D
If i was doing this in my backyard i would always remove the gearbox and engine, that way with the engine on the ground its real easy to line it all up again.
Stuff trying to get under the car to line stuff up.
Motor comes out with very little extra work if you have a hoist.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
