Have dynod a few RB25s with similar modifications. Standard pring limit seemed to be around 7000rpm running 20psi boost. Tune started to get ugly over & above this. the fittment of Tomei springs solved issue, can know rev the engine to 7800rpm at 25psi. Cars are tuned at UNIGROUP in Sydney. Can contact them for any further advise. 02 9631 2470
Does anyone know for sure or has had experience when valve float has started to occur in the 25's with whatever modifications they have had done?
Im curious to know if it happens often or not at all, i have yet to see anyone complain about 25det and valve float. Ive heard its a problem in neo25's cause their springs are weaker then the previous models, is that true as well if anyone knows?
  • 3 years later...
I know this thread is years old but Better to bring it back from the dead then to create another thread.
Anyone have any more experience with the stock valve springs on rb25det with bigger cams? I am using the Kelford 264's with 9.5mm lift.
I run RB30DET and keep the revs below 7100rpm and have not had any dramas with 2 bar and over 374kw at wheels but i do realise the bigger cams will be much harsher on the springs and could cause some issues.
Should i just replace the springs at the same time or just give the cams a go with stock springs?
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
    • Hydro lifters not bleed up could be the ticking noise
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
