Have dynod a few RB25s with similar modifications. Standard pring limit seemed to be around 7000rpm running 20psi boost. Tune started to get ugly over & above this. the fittment of Tomei springs solved issue, can know rev the engine to 7800rpm at 25psi. Cars are tuned at UNIGROUP in Sydney. Can contact them for any further advise. 02 9631 2470
Does anyone know for sure or has had experience when valve float has started to occur in the 25's with whatever modifications they have had done?
Im curious to know if it happens often or not at all, i have yet to see anyone complain about 25det and valve float. Ive heard its a problem in neo25's cause their springs are weaker then the previous models, is that true as well if anyone knows?
  • 3 years later...
I know this thread is years old but Better to bring it back from the dead then to create another thread.
Anyone have any more experience with the stock valve springs on rb25det with bigger cams? I am using the Kelford 264's with 9.5mm lift.
I run RB30DET and keep the revs below 7100rpm and have not had any dramas with 2 bar and over 374kw at wheels but i do realise the bigger cams will be much harsher on the springs and could cause some issues.
Should i just replace the springs at the same time or just give the cams a go with stock springs?
