Guest INASNT
Originally posted by gtst88
my friend fixed his S-AFC right at the top right corner of his windscreen and the cop that was checking his car for roadworthiness didnt see it .. well my friend got a canary because his exhaust piping was too low & an open pod filter .. fark cops ..
haha
didnt the cop see the wire coming down the side of the windscreen?
I have to hide my s-afc in my glovebox for my epa test
Guest INASNT
Originally posted by predator666
hey inasnt.. just open up the S-SAFC, disconnect the little plug to the board and it won't be able to rev past 2500rpm anyway :D I wonder whether they'd be too dumb to notice?
hahah that might b a plan, i can tell them my car is really a diesel and has the rev limiter set to 2500rpm.
Damn if i had a pfc i could have lowered the rev limiter to 3000rpm then they couldnt rev it past there if they tried.
Thats the only thing that suxs about the s-afc is that if u unplug it from the loom the stock ecu wont run properly!
Originally posted by DJ_L3ThAL
what about all the BMWs and lexuses who have bright yellow driving lights ? can i change my parkers to yellow ?
Xenons are the best - blue but legal! :P
A friend of mine has red angel eyes at the front of his car, but it's a BMW, so the cops don't bother him. :) 3 times cops have looked and not once have they booked him... ;)
Osram have good white bulbs too.
Xenons = HID = High Intensity Discharge = BRIGHT! = Expensive (A retro-kit for most cars will cost at least $1000 to buy (if it's a good quality kit))
:P
LED = Light Emittign Diode = Small, not very bright.
You can buy ordinary filament globes called 'xenon' but they are not. They have nothing to do with real xenons... A real Xenon bulb has no filament and will cost >$100. (Mine are $210 each!)
Originally posted by pushead
i doubt they will put this on record.. if they give you a warning don't worry about it.. they have 2 choices, either fine you or not.
If you send anything into Vicroads they'll keep it forever... yes FOREVER. Everytime you get pulled over the copper can bring up your vehicle record and check "comments" on the system detailling everything that has been wrong with your car in the past. As for hard copy documents, there a storage building in reservoir that has almost every single document anyone has given to Vicroads since it was set up millions of years ago... Basically they know how to cover their arses and drill people when they continue to disobey the "law".
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
