  • Replies 151
Posted Images
3" Dump Pipe and 3" Front Pipe (by X-Force) - $200
Get rid of that standard front and dump pipe and upgrade to a 3" system! This setup is in excellent condition and works very well (been tested for the last few days).
PM me if interested, will be taken off the car/s tonight for cleaning and packaging!
Thanks
Stan
i will take the the R34GTT Single Din Pocket with Spring Loaded Lid - $40. (only if you have one in grey colour)
also, i need the rear window water nozzle and rear speaker lids on the back shelf, they were drilled for restrants when complianced.
PM also sent.
Edited by PAV34
DIN Pockets all SOLD!
Washer Nozzle (rear) SOLD!
Speaker Grilles are part of the Rear Parcel Shelf and will not be seperated - entire unit is for sale at $80 + P/H
Thanks
Thanks to all those who have paid; the following have had their payments clear this morning - your items will be sent out today/tomorrow!
PAV34
NEO_R34
darrinspencer
Also, someone PMed me about the Driver Kick Panel Fuse Cover... I'm not sure who it was but if you are reading this please let me know as I have put it aside for you.
Thanks all!
PAV34
NEO_R34
darrinspencer
Thanks all!
That was me PM sent. :)
PM Replied... knew it was someone (well obviously)
Adding a few more items -
GTT Driver Side Kick Plate (Plastic/Black) - $50
GTT Passenger Side Kick Plate (Plastic/Black) - $50
GTT Standard Window Wipers (Front) - $40
GTT Standard Window Wiper (Rear) - $20
GTT Nissan Badge (from Boot Lid) - $15
Adding Items from Centre Arm Rest Assembly:
GTT Ash Tray (rear) from Centre Console - $30
GTT Hand Brake Lever Assembly - $75
GTT Hand Brake Leather Boot - $30
GTT Centre Cup Holder Assembly - $30
GTT Centre Arm Rest Console - $80
Package Price (all the above) - $200
* All the leather from both the Arm Rest, Hand Brake, and Boot are in excellent condition... plastic is currently filthy but will be cleaned up like everything else.
Sorry Side-Mount Intercooler is not available...
OK, someone has deposited money into my account from over the counter. It does not contain a description, only a postcode reference. If you have done so, please PM me to identify the amount and which branch you deposited from - cheers!
Shonen - sorry dude, hand brake and boot has both been reserved for sale until Wednesday - will let you know if it doesn't show.
Tom - Brake package (the entire lot) has already been snapped up!
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
