Adding a few bits:
Lower Control Arms (Left and Right Available) - $100each
Steering Rack (Two Available) - $250each
SpaceSave Spare (in black, not yellow) - $100
Stock Suspension Setup - $300
Driver Door Handle - $50
Interior Light Fascia (Front) - $40
Interior Light Fascia (Middle) - $40
Driver Seat Belt Assembly - $80
Driver Seat Belt Clasp - $40
Passenger Seat Belt Clasp - $40
That's about all for now... all in a weekend's work :P
S
  • Replies 151
Posted Images
Hand Brake Assembly and Boot is ON HOLD!
Air-Con Condensor + Dryer is SOLD!
SUGO: Parts to be sent out ASAP!
hayden49: Parts to be cleaned and sent out soon - awaiting address!
Driver and Passenger external Window seals?
The bits that the window slides up on the outside.
My car was attempted to be broken into, and they used a screw driver on that bit and split the seal.
I'm going to be in NSW (driving from Newcastle to Wollongong) might be able to pick up....
Esprit - no more DIN pockets sorry :O nuffsaid took the last one!
Bass - If you are talking about the seal that is at the base of the glass closest to the door then we have both available. Both are straight and mark-free. $80 each or $150 a pair.
If you are talking about the seals above the windows then both are gone sorry!
ABS Solenoid is ON HOLD!
Glove Box is ON HOLD!
Knee Support Bracket is ON HOLD!
A lot of people have enquired and seemingly showed genuine interest up till the point of payment - with so many parts floating around it is difficult to keep track of who wants what so if we don't hear back from you in a few days, we'll assume you don't want it anymore.
Fair enough?
Cheers
S
We have the seats but they are on hold at the moment for one of our mates... if the deal does not go ahead the seats will be listed on here.
Condition of the seats:
Excellent - No Fading, No Wear
* Needs a vaccum though, but this will be arranged prior to sale*
Thinking about adding my own stock airbox to the list of goodies for sale. Reason being I am getting one made up in CF ;)
Don't know how much to put on it yet, all I know is that they are in high demand!
Anyways, just a thought :P
If I do sell it, I'll lump it together with my K&N Hi-Flow Panel which has done all of 1,500kms before I whacked the pod filter on :thumbsup:
Thanks very much for that info Ed, will be in contact REAL SOON! :yes::cheers::banana: Champion!
Update:
ABS Solenoid & Control Unit is Sold
Passenger Side Indicator is Sold
Passenger Side Wheel Arch Guard is Sold
Negative on the Passenger Side windows... sorry, all other windows bar the Driver Side Quarter are available.
UPDATE:
I now have access to another complete brake package, that is everything you need (F/B calipers, rotors, master cylinder etc etc)
Same price as before $800 + postage - pleae PM me for more details!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
