We do have a full set. Dunno if they fit. Feel free to drop by for a test fit though. I'm sure they wont bolt straight in but 2 or 3 bolt holes may line up and then make some sort of bracket and you are away.
cool
just after front two seats. should get a chance next weekend
  • Replies 151
Posted Images
Nope sorry...
Just a random list (off the top of my head) to show what's still available:
* 3 inch X-FORCE Front and Dump Pipe for ER34
* All Interior Trim Pieces (well most)
* ER34 Stock Seats
* ER34 Stock Side Mirrors
* Driver side window
* Rear Windscreen
* Front Windscreen
* RB25DET NEO Engine Package
* R34GTT Stock Turbo
* Triple Gauge Cluster
* Fuel Filler Cap
* Standard Castor Rods
* Nismo Altia Wing
* Spacesaver Tyre (black)
* Heatshields
* Front Wipers
* Indicator / Wiper Stalks
* Glovebox
* etc etc etc
Only have the centre air con vents if I'm not mistaken... the climate control unit was sold in the early days of this wreck.
ill take that off your hands depending on price, also could you either post up or pm me a list of other interior pieces available plus a photo of the wing, thanks
http://www.skylinesaustralia.com/forums/in...c=114749&st=20#
That links to the wing as previously discussed in this thread. It's page 2 if that doesn't work.
As for interior bit's and pieces, there must be hundreds. It would far easier if you told us what you were after and we checked for it then priced it. Send Stan or myself a pm, handy to have pics in the pm also to help in identifying the correct part.
You can have the centre vent for $30 plus postage.
mxtcy; are you talking about the black surround that encompasses the centre console? The bit where your knees rub against?
Or are you actually talking about the centre console where the drink holder is?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
