Going by that picture its Viscous LSD which cannot be shimmed.
Carlos
iv asked a couple of diff palces and they've said 33's cant be locked up like the s13s by shimming..
is there a cheap way of locking up 33diffs or is the only option replacing it?
The viscous CAN be shimmed, its not really the best option but does work long enough for you to get some $$ together for a 'real' diff. :(
Essentially the only difference between the S13 and R32/R33 diff is the ratio, back plate and half shafts (different bolt up). The housing and diff center are the same.
thanks for the replys,
looking at the pic, what shim is it i would need to get, part 38453 x2 or part 38454 which there is only 1 of. nissan quoted me 35 bucks each for part 38453 and they come in different thicknesses.
thanks
again
The S15 helical is good for handling and getting power to the ground HOWEVER they are a little weak and break up around 200rwkw.
Yeah a knew that already :D i have a good friend who has an s15 and i love the way his diff works. I have seen one for sale cheap recently, and my original question was can i fit it on my r33 gts-t???? if i can for cheap it would be a good handling upgrade.
Yeah a knew that already :( i have a good friend who has an s15 and i love the way his diff works. I have seen one for sale cheap recently, and my original question was can i fit it on my r33 gts-t???? if i can for cheap it would be a good handling upgrade.
I have been reliably informed that it will fit the housing but the splines on the out put shafts are different to all the other vlsd diffs so you have to use the s15 ones. I have seen it done in a couple of s13's.
What that means for skyline owners is that you will also need to swap driveshafts. In an r32 not so much of an issue as s13 6 bolts shafts will fit.
The extra cost of the shafts and the reduced drive shaft diameter may be an issue. Thats what's put me off that idea.
ok I dont know if the dif is the same as the R32 but I would asume the shim used would be pritty close this is what im going to use for mine and heaps of ppl use for drift, "and yes its off a 300zx" in case the nissan guys ask lol
part number: 38424-40F68
description: WASHER-THRUST, SIDE G
unit price: $15.78
That is so tempting to get just a little more life out of my diff.
7yphon, as your in the circle, how would this shim help an almost completely stuffed vlsd diff?
As a rough description of its condition it will spin one wheel through first and some times twin up second in a straight line without any nasty clutch dumps/gear slaps. All though clutch dumps/gear slaps do tend to have it twin up more often than throttle roll ons.
Hot 35+degree weather after driving on it for a while has the diff locking up almost perfectly.
unit price: $15.78
thank mate :D
From what I heard the cluch pack or whatever gets a little sloppy the older is gets. The shim is surpose to go onto the old shim to put it near stock or even further. I am not really too sure about stuffed ones but what you said sound like you might have another issue, BTW Woolls this is only a temp thing because they need to be replaced I would suggest shimming it and then saving up some dosh for a decent 2 way
The R32 and R33 GTST's run a Viscous LSD.. They don't run clutch packs.
Viscous works on the principle of one wheel spinning heats up the viscous fluid that expands and locks the two wheels together. As they age they begin to open wheel. Why shimming works on these diff's i'm am not completely sure, but it does. To some extent.
Have a read of the LSD wiki to so you understand a little more about diffs. :)
http://en.wikipedia.org/wiki/Limited_slip_differential
thanks again,
not going to muck about with shimming the diff now, i ordered a new kaaz 1.5. should be here this friday :)
Edited by woolls
  • 5 weeks later...
thanks again,
not going to muck about with shimming the diff now, i ordered a new kaaz 1.5. should be here this friday :dry:
Hmm.
How much did that cost you and where did you order it from?
I was thinking of shimming mine (r32) but after reading this thread im not overly sure its the right thing to do.
Hmm.
about $1200 delivered. send RMS an email for a price. here is a link
http://www.rmsmotorparts.net/HomeFrameset.htm
cheers
Leigh
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
