OUCH!
and oi Chris.. You might provide the cable ties, but remember I'm the one that does the tieing! :(
oh, and I'm with thomas RB26!
This is a VERY complex discussion that can go on for ages, and will surely piss the rest of the whores off if we discuss it in this thread, but in a nutshell, all things being equal, a normal stroke RB26 is better for big power on street fuel than using an RB30 crank for the following reasons-
*The piston speed is lower at the same revs
*There is less side thrust exerted on the bores by the pistons, due to less conrod angular/side motion (less heat/friction)
*The Piston spends more time in the dwell state at TDC and BDC
*The Bore/Stroke ratio is much better (over-square engines like to rev harder)
Which helps, briefly, with the following
*Keeps frictional losses down (engine lasts longer, makes power more easily)
*Helps secondary balance
*Optimises manifold air speed at high revs
And blahdy, blahdy, blah. [/end rant]
Nissan could have made the engine 3L if they wanted to, but they didn't.
P.s 2JZ's and RB30's both have around 6800rpm limits from the factory, which is the same piston speed as an RB26 at 8000rpm.
  • Replies 240
Ouch... how much damage to the head (esp the combustion chamber on 6)?
Pretty respectable effort, haven't seen something that smashed for a long time!
Edit - that quote from R32R at the top of the page is wrong, very very wrong. I think he's got things crossed up.
That's what I thought too but I'm glad somebody more knowledgable than me said it first.
But but but, if RB30 bottom ends are so good, then why can't I get a crate engine with an RB30 bottom end shipped from Japan? (innocent look)
No one will do it for me! They all say something along the lines of, "Are you stupid?" (innocent look)
(...stupid for asking them to build it, not stupid for asking them to build one and send it)
Seriously though, I'd like to hear someone that is all for RB30's tell me why they're better. I have no idea.
..uhm..so as not to hijack mona's thread, this is for your benefit too moonie :huh::(
i've heard RB20DE
It will be sweet when it has the CA18DE in there, should be an animal,ooops I've said too much.........
Personally, I'd be going for an L16 and turbo, blowing through a decent sized carbie of some sort - 45mm Weber, Dellorto or SU, side-draught of course... :huh:
im sure u can cable tie it back together.. no biggy
Bit of gaffa tape and she'll be all good again..
Ahhh, cable ties and gaffa/electrical tape - the drift/drag/circuit racer's and mechanic's best friend! :(
Seriously though, that is some heavy duty damage. :rofl: Mona, you should keep the parts and display them somehow for memories. Ahhh, the good times!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
