OUCH!
and oi Chris.. You might provide the cable ties, but remember I'm the one that does the tieing! :(
oh, and I'm with thomas RB26!
This is a VERY complex discussion that can go on for ages, and will surely piss the rest of the whores off if we discuss it in this thread, but in a nutshell, all things being equal, a normal stroke RB26 is better for big power on street fuel than using an RB30 crank for the following reasons-
*The piston speed is lower at the same revs
*There is less side thrust exerted on the bores by the pistons, due to less conrod angular/side motion (less heat/friction)
*The Piston spends more time in the dwell state at TDC and BDC
*The Bore/Stroke ratio is much better (over-square engines like to rev harder)
Which helps, briefly, with the following
*Keeps frictional losses down (engine lasts longer, makes power more easily)
*Helps secondary balance
*Optimises manifold air speed at high revs
And blahdy, blahdy, blah. [/end rant]
Nissan could have made the engine 3L if they wanted to, but they didn't.
P.s 2JZ's and RB30's both have around 6800rpm limits from the factory, which is the same piston speed as an RB26 at 8000rpm.
  • Replies 240
Ouch... how much damage to the head (esp the combustion chamber on 6)?
Pretty respectable effort, haven't seen something that smashed for a long time!
Edit - that quote from R32R at the top of the page is wrong, very very wrong. I think he's got things crossed up.
That's what I thought too but I'm glad somebody more knowledgable than me said it first.
But but but, if RB30 bottom ends are so good, then why can't I get a crate engine with an RB30 bottom end shipped from Japan? (innocent look)
No one will do it for me! They all say something along the lines of, "Are you stupid?" (innocent look)
(...stupid for asking them to build it, not stupid for asking them to build one and send it)
Seriously though, I'd like to hear someone that is all for RB30's tell me why they're better. I have no idea.
..uhm..so as not to hijack mona's thread, this is for your benefit too moonie :huh::(
i've heard RB20DE
It will be sweet when it has the CA18DE in there, should be an animal,ooops I've said too much.........
Personally, I'd be going for an L16 and turbo, blowing through a decent sized carbie of some sort - 45mm Weber, Dellorto or SU, side-draught of course... :huh:
im sure u can cable tie it back together.. no biggy
Bit of gaffa tape and she'll be all good again..
Ahhh, cable ties and gaffa/electrical tape - the drift/drag/circuit racer's and mechanic's best friend! :(
Seriously though, that is some heavy duty damage. :rofl: Mona, you should keep the parts and display them somehow for memories. Ahhh, the good times!
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
