  • Replies 240
best thing for you to do mona if all you want is 250 KW is just buy a bare motor and put your bolt ons on it.
Otherwise if you do want more power
depends what you wanna use the car for in the end
Im selling my car cause ive got a new project comming
aiming for the 800Kw mark and in the mid 8 second passes.no point in wasting my car just sell it and start fresh
Interesting. Buster's right. They all have their place and not just from a performance perspective. There are other things to consider. I looked at the rebuild NEO or go RB30 thing recently when mine blew and decided that the rebuild suited me best. I'm happy with my choice and enjoying it.
from what it seems its overly sensitive. this can happen from having the sensor to tight.
the pistons are perfect. not a whisper of detonation
I got this problem with my 3 litre.. it allways knocks on the PFC but we can never hear it at all!!!
I took it to many dyno's and they tuned it with knock levels of around 100 yet there was no detonation because we could not hear it at all.
They told me to ignore the knock level because its not knocking.
My knock sensors used to work ok till the 3 litre went in to maybe we tightend them up too hard ??? how do you know when its in too hard ??? how to you get it right ?
Edited by Guilt-Toy
I took it to many dyno's and they tuned it with knock levels of around 100 yet there was detonation because we could not hear it at all.
from memory its 15nm. with a lubricated thread. so yeah. just nipped up
basicly the same tension as the ignition coil holders.(the 12mm bolts)
I did not even know about the coil holders not needing to be in tight lol
Got any other usefull information for us ? =)
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
