Bad luck Mona. Will be interested to know if it's oil or fuel related.
Hows the oil in the sump look? Lots of golden flecks? May have just been a rod let go too. How does that look on the gudgeon (piston) end where it snapped off?Looks beaten on the lower part of the rod.
My advice for a daily driver though is RB25 with the right work and the right turbo. 26 is too lazy low in the revs and if you have a grabby clutch you will get some spin trying to get the thing going in the wet with RWD.
All the best on the new one and please post whatever you want in my thread below.
  • Replies 240
boost - 1bar
well confirm if the fuel pump is still working on not.. as far as i know she still is!!
Geoff - will do!! and yeah... losts of scrap metal and water droplets :w00t: Couldn't see the piston end.. only had a top view... so can't tell you what it looks like!
it's not that complex moonie..
look for the user CUBES. in his signature, he has a PDF file which is like a DIY rb30det guide.
go from there..
if you are going to be paying someone to fix your motor for you, might as well get them to do the 30 for ya.
probably cost less.
considering bottom end costs about $100
if you want forged goodies, then both bottom ends will cost the same.
small mod to the vvt oil line
small mod to the engine mounds and your done.
so to speak
Moanie who is having a look at the engine? like Geoff said it seems like the piston failed at the gudgeon pin which is pretty unusual? And we can't really tell if the rod broke as well.....and presumably when it all let go the piston mashed into the valves and head at eleventy billion miles per hour.
Normally pinging will blow out a ringland and you will loose a heap of compression before a rod or pin fails, so I'm wondering if there was some other cause?
moooooona
you had what, 250rwkw before?
on the same boost, on a STOCK (read: stock pistons, rods, crank, gasket etc) RB30 bottom end, you would have that power or more, with loads more torque earlier in the rev range, and would be more reliable.
If your head is ok, it would be the cheapest option for you.
if the head is gonesky as well, then you need to look at it a few more ways.
stock second hand rb25det from wreckers?
stock rb30 bottom end, with stock rb26 head with new rings and bearings?
I've seen rb26 heads complete with manifold, injectors and so on for about $2K
Justinfox is selling a pair of 2530's for $1K (one has s blown seal or something but thye were both built by GCG using HKS cartridge or something)
All bolted together you'd have some spastic amounts of power which a little girl like you could ever want.. :)
Not sure what sort of $$$'s you are looking at spending here or can afford to spend but think it all through and do the math before making a choice.
Finally... if you ever need someone to point and laugh at your misfortune, you know where to find me. well for the next 3 weeks anyway
hahahahaa... yes indeed i do!!
thanks for the ideas! i'll look into those options.. it really does come down to what i need to fix! but we'll see!! and i have no money at the moment!! jsut what i wanted to spend on rims!!! so i'll be going a cheapish option as well!! we shall see! :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
