  • Replies 240
hello mona
Sorry to hear about you motor.
I got some parts laying around at my shop if you need something. Standard cranks,rods,ETC.
As for the engine, I wouldnt really blame the Tuner.Sounds & looks more to an oil surge which could of been a long thing comming.
As for this rev limit business,I sit on the limiter which is 8200RPM doing my burnouts with the standard motor on 18 psi.As doughboy and buster have seen.I wouldnt blame hitting the rev limiter.
What is you rev limit set on mona and do you have an oil Pressure guage in the car.What oil do you use in your car.
my opinion on the cause is either
-Rod gave up
-Oil surge
For this to be caused by pinging the pistons would of all been rounded on the edges due to detention.
Good luck with your new build.I would stick to the RB25.RB26 if you want to spend the money. I wouldnt recommend going to the RB30 stage till you wanna run in the 9`s.
I don't think i ever blamed the tuner?! but i did say my car has a very long history of pinging... i NEVER had a ping free tune!! on the road.. most times... on wsid... i always saw the check engine light flash and would fix by chucking in octane booster!
rev limiter is set to about 7.5k i think... and i VERY RARELY hit it! even at ec! i did hit it once or twice when i was still learning where it was.. but thats all... and on the track... i don't think i hit the limiter at all!!! there isn't even enough room to!
it was an oil surge and not detonation like i previously thought.. but it does look like (as adrian has stated) that there was some detonation... and my mechanic did see alot of damage due to detonation in the engine... it may very well have been a combo of both!
no oil pressure gauge and i use motul!
thanks for the offer for parts... i'll keep that in mind! :)
yess. oil surge is the suck. hope all are learning from this debarkle
and there was no evidence of detination on any of the good pistons. so chances are you propbably had a dicky knock sensor..or they were done up to tight on the block
ie.. track use you MUST add at least an extra 1-1.5 litres of oil. but any way...back the the great debate.........:
for all intents and purposes a 3litre would be the go. i have given this much thought.
from having a 330rwkw dr30 i know traction will be very limited on the street.
so either way a 3litre or 2.5 doesnt really mater. from a budget and down time point of view id do a 2.5.
but for the wow factor and ultimatly the better setup for the street id go 3litre.
besides. why rev it past 7k anyway. i know mona doesnt like lag so chances are itle have a relativly small turbo.
clearly the combo works whether it be with a 26 head or 25 head. so you have my support either way
cool. a anti 3litre argument. :)
Not really just misinformed parrot quoting information and being corrected, I too get sick of all the go RB30 talk as its not always the best or easiest solution as I keep saying each RB has a place if only we could all get over our oooh RBXX is the best attitudes and keep open minds :P
hahaha... nah.. thanks morgs :D
i really am still deciding! its alot of money to consider! my mechanic is putting together a pricelist with possibilities.. it really comes down to what i'm willing to spend... and depending on my mood down the track it can range from alot to very little...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
