without listing the full car specs
its impossible to tell
it might be cheaper for a 2530.
depends on every mod that you have not listed
hey r31nismoid, say with the basic mods:
- boost controller
- 3" dump/front
- 3" hi flow cat
- 3" catback
- fmic
- safc
- fuel pump
what would you prefer from either turbos that would produce more power, hi flow or 2530?
what would pull better 1/4 mile times?
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2114754
the 2530 will peak and drop off more im pretty sure. the rb25 turbo upgrade thread has plently of hiflow and 2530 graphs to look at and compare against. the 2530 is probably cheaper but the hiflow will perform better i expect
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2114995
just for some information
i just bought a hiflow for 800
it did have a bit of play in it, and it is plain bearing turbo.
it cost me around 200 bucks for the rebalance, and 270 thrust bearing.
not sure what size wheels are in the turbo, but on my stock turbo i ran 12 psi and had 201rwkw.
with the hiflow i notice a significant difference in power, and spool time.
and when it winds up now, it sounds like a truck.
i ran a 14.089 with the stock turbo, but it was only my 4th time out there
and i didnt get my starts as good as i would like
i'm hoping to rund some low 13's next time i get out there and put the boost up to 15psi.
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2115369
GCG don't do two stages anymore I don't think. The stage two had compressor surge issues.
SAU NSW members get 10% discount at GCG.
I reckon for an R33 GTST then a 2530 would get down the quarter quicker. Just so much mid range punch.
Aquariz you should get a powerFC with your turbo upgrade if you want to take full advantage of it.
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2115726
i thought the hi flow turbo is meant to be stronger?
i know 2530 kicks in quicker then hi flow because hi flow kicks in the same as stock
doesnt it also have a big mid range punch similar to the 2530?
does anyone have a dynograph of the rb25 stock turbo and a hi flow... would like to compare
yea abo bob i wish i could get a powerfc on my car... just hate the fact that i cant... auto transmission
i was wondering which from the 2 and a gtrs will have higher rwkw by 5000revs? anyone?
Edited by aquariuz6
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2115834
Look, it's not the worst turbo in the world and they didn't have surge issues with all of them, just a fair few. It might be ok but it might be the reason the current owner is selling it.
I get full boost of 0.9 bar at 3200rpm but I do notice that it spools very early, just takes a bit to get full boost.
I think 2530 to run 12's is a proven combo. For some reason I don't seem to notice decent times with highflow turbos. I'm running 13.4 atm and I wont bore you with my issues but the weird thing is that I run very good times on the roudy roundy tracks. Maybe I'm just no good at the short one.
But still there it is, I've got 255rwkw with a highflow but I can't get a 12 but it has been proven that 220-240 from a 2530 will get you one.
Watch this space though. I might get there yet with a little practice. Going to a test and tune day soon.
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2126154
The 2530 Probably provides more average power and at lower revs hence the better times. Got a dyno sheet by any chance?
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2126821
My Hks 2535's failing after 75k kms due shaft play setting in and making wailing noise. Have ordered the
gt-rs and hope its a better choice than 2530kai. The gtrs is stronger from 3000rpm and has just slightly less response <3000rpm. From Hks web:
gtrs: graph_01.gif
2530kai: graph_02.gif
Edited by docang
https://www.sau.com.au/forums/topic/114828-performance/#findComment-2165548
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a tool to do a one-time job, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
