' date='12 May 2006, 05:41 PM' post='2162330']
its a slightly thicker cooler but will mount just the same. be aware that you will have to plug up a hole as the r34's use a sensor in the cooler
Who told you they have a whole?
  • 5 weeks later...
  • 1 month later...
' date='29 Jul 2006, 10:28 AM' post='2366515']
are your eyes painted on? you can even see it in the middle picture
Mate...why get stuck into someone when you have not idea??
They don't have a hole for the sensor, it is just a recess...but then again, I'm sure wrxhoon knows that since he has a BNR34 with OEM intercooler and has had it out a few times...
Guys guys guys,
Rather then guessing... if any of you owned a R34 GTR like me and have changed the standard cooler you would know what your talking about!
IT IS A HOLE!! and unless he gives you the inlet temp sensor you will need to either make your own or get the hole welded up.
Guys guys guys,
You are wrong buddy they dont have a hole there at all.
I have one in my BNR34 , dont you think i know? Just like Mick said they have a place for the temp sensor.
If you want to put some money on it , i'm happy to take it of your hands .
No mate my eyes are still excelent , thats the reason i know there is no whole there . But how would you know? have you ever seen one for real? I have one in my BNR 34 , you are only going on the pic and your poor eyesight!!!
:yes: With a name like WRXHOON its no wonder you don't know what your talking about!!!!
To the person thinking of buying this for there R32 they have a hole so rather then taking any advice from these morons ring any good GTR workshop and ask them, then you will know and they might be able to help you with making a senser or welding up the hole.
WRXHOON stick with your elastic band WRX'S!!! :happy:
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
