Have for Sale a Greddy T78 33D 17CM
Only used for 6 months on a 98 RZ supra..
$1600 FIRM
and
HKS T51 Turbo
A/R .72 (Garret front cover)
Rear housing- says HKS 080 (not sure)
Turbo is in Good condition
Comes with a braided oil line
$1000 FIRM
email: [email protected]
Sunshine Coast QLD
First 2 pics are of the T78
ext 3 are of the T51 with the cover off
Edited by buttocks
https://www.sau.com.au/forums/topic/114835-greddy-t78-33d-17cm-and-a-hks-t51/
