Now A Fellow Stagea Owner
3 week of ownership gone.
Installed a HKS pod filter this week, amazing how much the top end opens up.
Also changed the sound system over to PAL compliant CD/DVD/MP3/ Digital TV option..... this is with Mel's old Alpine monitor, so if anybody needs the Jap system or bits from it (All Addzest - Sat Nav, Digital Sound Processor, Monitor, Head unit).
We think we have found a CHEAP solution for the NTSC/ PAL problems in getting the Jap TV system to work here..... but seeing as we had the Alpine unit already, utilised that.
GSM pager alarm being installed today.... no problems with being out of range like other pagers, this one rings your mobile phone! Again if others are interested, I can arrange a group buy for under $400 each.
QUESTION: What is the purpose of the 4wd looking button on the dash fascia, sits under the wiper stalk:
S
Edited by Pawley
Explain the cheap way! :)
S
3 weeks, nice.
Button query; to lock 4wd 50:50 F/R on, or when off normal ecu controlled (what 20:80 F/R maybe?)
I reckon its handy to have on, with snow mode on, on a cold wet slippery dark winters night, at the traffic-lights GP.
Edited by Tangles
