Fs: Mad Turbo
located in thirlmere nsw, selling a high flowed nissan rb25det turbo. ratd at 500hp, it has the following specs:
high flowed turbo off a s1 nissan skyline. it has done 5674klms since being built, has no shaft play, has only run at 10psi, and is capable of 500hp. it has the following work done to it... high flowed machined front and rear housings, larger steel internals, new ball bearing packs, larger wastegate, new wastegate actuator (factory set to 10psi minimum), and ported exhaust housing. excellent condition. email me for pictures. cost of tthe turbo build was $1950.00, plus $450 for the turbo. now you can see how much of a bargain this is. It was rebuilt by xtr (gcg turbos).
make an offer or bid here http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
looking for around $800.00. i know it mite sound expensive, but it is a direct fit. no new manifold, pipes, etc. and its a great turbo
will it be a direct fit to a 96' s2 r33? The only mods i currently have are front mount intercooler, 3.5" cat back exhaust (getting dump and cat done this week) would i need any other mods to support the turbo? or could i just get a mechanic to whack it on with low boost?
Also when does the turbo come on boost? do you have any dyno graphs?
Edited by lukes146
it will be a direct fir. it would take about 3 hours for you to fit it yourself. and i dnt have any dyno graphs, but i can say it hits 10psi by 3200rpm. then goes like an ethiopian running to macas
hahahaha, love that ethiopian joke. alright you might have found yourself a buyer. Do you have the receipts for the build? and why are you selling the turbo?
unfortunatly my mechanic has the reciepts as he sent it to gcg, but the serial number is :AA428.
the receipt is available from gcg turbos. im selling it because the motor since shat itslef, so its the perfect reason to build a big f**k off 800hp motor. :) i have bought a gt42r and need more moolah if you no what i mean,
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
