located in thirlmere nsw, selling a high flowed nissan rb25det turbo. ratd at 500hp, it has the following specs:
high flowed turbo off a s1 nissan skyline. it has done 5674klms since being built, has no shaft play, has only run at 10psi, and is capable of 500hp. it has the following work done to it... high flowed machined front and rear housings, larger steel internals, new ball bearing packs, larger wastegate, new wastegate actuator (factory set to 10psi minimum), and ported exhaust housing. excellent condition. email me for pictures. cost of tthe turbo build was $1950.00, plus $450 for the turbo. now you can see how much of a bargain this is. It was rebuilt by xtr (gcg turbos).
make an offer or bid here http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
looking for around $800.00. i know it mite sound expensive, but it is a direct fit. no new manifold, pipes, etc. and its a great turbo
https://www.sau.com.au/forums/topic/114893-fs-mad-turbo/
will it be a direct fit to a 96' s2 r33? The only mods i currently have are front mount intercooler, 3.5" cat back exhaust (getting dump and cat done this week) would i need any other mods to support the turbo? or could i just get a mechanic to whack it on with low boost?
Also when does the turbo come on boost? do you have any dyno graphs?
Edited by lukes146
https://www.sau.com.au/forums/topic/114893-fs-mad-turbo/#findComment-2115393
it will be a direct fir. it would take about 3 hours for you to fit it yourself. and i dnt have any dyno graphs, but i can say it hits 10psi by 3200rpm. then goes like an ethiopian running to macas
https://www.sau.com.au/forums/topic/114893-fs-mad-turbo/#findComment-2115406
hahahaha, love that ethiopian joke. alright you might have found yourself a buyer. Do you have the receipts for the build? and why are you selling the turbo?
unfortunatly my mechanic has the reciepts as he sent it to gcg, but the serial number is :AA428.
the receipt is available from gcg turbos. im selling it because the motor since shat itslef, so its the perfect reason to build a big f**k off 800hp motor. :) i have bought a gt42r and need more moolah if you no what i mean,
https://www.sau.com.au/forums/topic/114893-fs-mad-turbo/#findComment-2115449
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
