Hey guys,
I have recently had my car fully retuned & since getting it back, everytime i shut the car off it seems to want to keep going. What i mean is when i turn the key off the engine is still trying to run, but sounds as though its out of fuel or something. Why wont it just fully shut off when i turn the key?? The tuner seems to think the pistons have carbon build up on them??
Any help would be great! Thanks
Hey guys,
sounds bout rite. carbon on your valve/pistons can glow, causing a deisel effect. basically the air and fuel are stil getting sucked in but instead of the spark plug igniting the mix, the glowing carbon buildup is. you should get it fixed, as at high revs, this could cause detonation, and demolish your engine.
Sounds like your injectors are incorrectly wired up to 12V constant.. meaning when IGN is turned off, the spark continues. It's only when the fuel in the rail is expended that the motor cuts out.
You don't have a turbo timer hidden away or anything like that?
I'm not sure about the carbon continuing to burn.. but it's possible in theory.
Is there any way to get this carbon off?? Im not sure if he touched the injectors? I assume not.
He mentioned that its running 22deg timing?? Its just got me puzzled, as this never happened to it before it went in for the tune. & he cant think of what it might be also.
Is it bad that this is happening??? Will it wreck my engine??
thanks for your help!
any other help??? :P
If it wasn't doing it before the tune then it _has_ to be something your mechanic has done and he needs to fix it. Stock ign timing for an R32 GTR is 20degBTDC, so 22deg is not too far out. I'd suggest that your mechanic needs to look at the work he's done and if he's any good he should be able to identify the things that would cause or contribute to the problem.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
    • nice work, welcome to the world of CAD! fabricating accurately in 3 dimensional space is beyond me....I almost always end up making something more than once...sorry I mean I extensively use prototyping
