Hi all,
Unfortunately I have been told some rather disturbing info.
I thought I would pass this on as I would hate for something to
happen to anyones car, as I would be pissed if it was mine.
Apparently these people are only targeting Skylines, they are stealing them and
dumping them in the bush stripped and burnt out.
Cars that are fitted with security devices are being stripped for parts.
They are taking anything they can.
I was told this by a fellow SAU member and we thought we should let everyone know
Please people be careful where you leave your car and if you see anything suss report it
Krissy
https://www.sau.com.au/forums/topic/114968-skyline-thefts-in-newcastle/
Bad, bad news.
Thanks for the heads up...
Im sure everyone who owns a Skyline already takes extra care with where they park it/how long for etc...
But obviously now the people in Newcastle will just have to take a little extra.
Yeah but some ppl can't get full comp like us youngins it sucks :) the most disturbing news is our only alternative Alarms, and you say alot are getting past them.
Michael
im only 22... theres alot of car theft up where i was living before newy so i didnt really have a choice.
but even then, alarms??? how often do you hear one go off and most ppl just walk by or get annoyed at the noise? :)
but even then, alarms??? how often do you hear one go off and most ppl just walk by or get annoyed at the noise? :ban:
and you would sh*t yourself if you knew how easy they where to by-pass when you know what you're doing.
(i mean alarms and immobolisers)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
