  • Replies 69
Has anyone used Garrett 2560-10s yet? I want to use a pair in my wifes Tomei 2.8 thats slowly happening but would like some feed back before i make up my mind.Yes i know everyones going to suggest a big single but a GTR is twin turbo in my mind and will stay that way.
I care not for Drag racing ,Track is the place the car will be used.
Yeah arguably what makes the TO4Z cartridge is its TO4R compressor , the P trim turbine is a bit long in the tooth nowdays and long overdue to be replaced by one of the GT UHP turbines in a sensible size and trim .
The HKS version gets a leg up from housings that are not truck diesel types and can have custom AR's and diffusers to optomise for petrol performance apps .
Their GT2510 is old and old thinking compared to more modern GT28BB combinations , they learnt to lower the boost threshold by going down in comp trim rather than turbine trim and style . A couple of the SR20 spec GT-SS cartridges would be very interesting on an RB26 as they are basically a GT2530 cartridge with 60 rather than 63 trim compressors . Garrett sells this cartridge as well from memory .
Out of time cheers A .
  • 3 months later...
I should grab some photos as it makes a lot more sense in pictures :mad:
I've attached a couple of pictures of the install I've finally got around to getting of the father's digicam. I've made some notes in the pictures. I'll try to remember to take some more (particularly of the front turbo and its support, and the top of the aircon outlet in the firewall) next time I have the car in bits.
  • 3 weeks later...
Justin, as with several others, im running the HKS GT-SS's with Tomei Type B Poncams and making around 320awkw on a very safe tune.
The norm for most people running this turbo/cam combo seems to be around 315-330awkw, dyno and engine specs depending.
They are an awesome street turbo, particularly if you are looking for response.
I have garrett 25/60 and make around 228 kw at 5000 with a peak of 367 what does your car make around that rev range?
How hard was it to wrap the trust dumps? How much did you use in the prosess? I've ordered these dumps, and i'm currantly pulling out my turbo's and putting some 2530's in. (If I ever find who designed the R32 engine bay, i'm gunna kick em in the nuts)
Do you have anymore pics of your modding?
I would get them ceramic coated rather than wrap them (if I had my time again). When you put the dump pipes on the exhaust flange of the turbos the studs are extremely close to the dump pipes so fitting the nuts on is an absolute bitch, so much so it was impossible to have the wrap right up to the back of the dump pipe flange (the nut just wouldn't fit with the extra thickness from the wrap). YMMV. Some people haven't had this problem.
I can't remember how much wrap I used exactly. I bought one of these DEI Thermal kits. I am pretty sure I still have one of the 50" rolls left (but don't quote me).
I'll send you a more detailed explanation view PM.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
