This problem has been happening some weeks (has a couple of posts about it but i can seem to get on my other login), andyway ill be driving then suddenly my steering gets very heavy (before hand it is perhaps lighter than normal) and after some minutes my HICAS light turns on. Then i turn the car off and on and have normal/light steering for 30 seconds - 10 minutes before once again it gets heavy again. I noticed now that it seems to only happen when i have over half a tank of fuel. A full tank meaning it occurs most often and a half full tank or less meaning the problem occurs never or not often.
Any help would be appreciated because at the moment i am trying to save up for a tune up and dont want to spend money trying to fix the hicas
Also i noticed tomei has a kit on the nengun site which disables the hicas electronically and mechanically and doesnt require more work than some wiring. Would installing this be likely to fix the problem
Thanks
https://www.sau.com.au/forums/topic/115007-hicas-weirdness/
30 minute installation, a $150 lock bar and a wheel alignment and u'll never have to worry about the HICAS again ;)
Uhmm yeh i didnt really like the idea of installing the lock bar though. Was hoping that tomei one would do the trick ahhh.
Any other suggestions from any 1 at all which would help solve the problem would be verrry much appreciated
https://www.sau.com.au/forums/topic/115007-hicas-weirdness/#findComment-2118149
  • 4 months later...
